Old 01-13-2008, 08:24 PM   #1
Sunset Coast's Avatar
2008 31' Classic
Benton Harbor , Michigan
Dump Valve Lighting
Has anyone replaced the small light above the dump valves, just behind the wheel well on my '88 Excella, with LED lighting? I am replacing that section of the wrap that holds the light and would like to install something newer (and that works). I have been looking at Super Bright LEDs list of possible options ... anyone use these?
ID:	52499   Click image for larger version
Name:	LUXART LED module.jpg
Sunset Coast is offline   Reply With Quote
Old 01-13-2008, 10:27 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
You have a light for your dump valve? I have to get a newer trailer!
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 01-13-2008, 10:39 PM   #3
_
having totally drained the coach batteries a time or 2 in years past by leaving the the dump valve light on...
i now NEVER use it.
like me it's not very bright anyway.
the issue with an led replacement is finding one BRIGHTER than the current bulb.
as in 1 watt or more and non directional...
you'll have to buy and try i'm afraid.
i find it easier to just use an led flashlight or 'personal head light'
or not do the dump thing in the dark...
i SO don't wanna step in it.
cheers
2air'
Old 01-14-2008, 07:38 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I like 2 air's solution, I have also seen gloves with led lights on them. Just aim your fist at whatever you want to look at. Hands-free, and it doesn't have the geeky-coal-miner look.
Also, Janet, our '74 has dump-valve lights. Maybe you should get an unpainted Argosy.
Old 01-14-2008, 07:42 AM   #5
Central , Mississippi
Originally Posted by overlander63
... Maybe you should get an unpainted Argosy.
Perhaps they sprayed over the bulb!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-14-2008, 07:53 AM   #6
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
I have left our dump light on once or twice during the dark early evenings of early winter while camping but we were always on shore power. I too have made changes to the way I do things; no more light and only dump when there is enough natural light to see what I am doing. This way I advoid having any accidents!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 01-14-2008, 08:06 AM   #7
Garfield's Avatar
2001 25' Safari
London , Ontario
Images: 24
Our dump light and switch is broken on our Safari - it's item the dealer is fixing. I'd prefer a high intensity incandesent bulb that would illuminate the whole area - plus it would be obvious if it was left on by accident. IMO LED's are great for being seen, but are lousy for illuminating.
Gary & Debbie
2001 Safari 25 SS
2011 Chevy Traverse 3.6L AWD Hensley DirecLink McKesh
Set-up by Can-Am RV
Garfield is offline   Reply With Quote
Old 01-14-2008, 08:31 AM   #8
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
The futures so bright I got 2 ware shades
I added a little lighting to compliment the dump light.
Michael
ID:	52513   Click image for larger version
ArtStream is offline   Reply With Quote
Old 01-14-2008, 10:49 AM   #9
_
you da man artzilla!
and don't those lights double as an incinerator at the pooo valve?
notice folks there are NO umbilicals on that unit, it's a nuclear thing...
check out the fridge vent street side, no moldy cheese in that baby!
beam me up scotty...
cheers
2air'
Old 01-14-2008, 11:27 AM   #10
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I have converted all exterior lights on my Safari to LEDs. The only one I have not changed has been the dump light.
Using a fuse to light up all the exterior lights (minus flood light and step light), I guess that with all the LEDs on, I am using maybe the equiv of one standard light bulb, if that.
Before going LED, putting the fuse into the umbillical trailer hitch wiring, I'd get a fair spark, cross a 10a fuse into the plug. Since going LED, I have gone as low as a 5a fuse and may even try lower amp fuses.
If I ever use the dump light, I will for sure change it to an LED type as well.
Not cheap for sure, but far less than it use to be and in a year or two, maybe even less than it costs now.
Old 01-14-2008, 02:00 PM   #11
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Like 2Air, I don't even connect the sewer hose when we arrive after dark. I just wait 'till next morning and make the connection then and dump during the day light hours.
Family of Disney Fanatics
WBCCI# 4821
Old 01-14-2008, 02:28 PM   #12
Images: 59
I thought those lights were required, so the campground police could check your drain valves late at night.
We don't want anybody watering the grass by accident.
markdoane is online now   Reply With Quote
Old 01-14-2008, 06:55 PM   #13
2008 31' Classic
Dump the Dump Light?
Thanks 2Air for the idea, but I think I will pass on the "headlamp"
ArtZilla, it is still awesome to see your trailer "lit up". That must be the reactor behind the fridge vent!
Great suggestions all. I am going to find an LED light that I like and try it out on the dump valve (do they make brown LEDs???)
Old 01-14-2008, 07:14 PM   #14
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Come into the light
Roxxxannnnn, you don't half to turn on your dump lite, ROXXXXANNN....
M
dump valve (once again) eubank Waste Systems, Tanks & Totes 13 09-08-2007 10:56 AM
Dump Valve Sneakinup Waste Systems, Tanks & Totes 27 05-23-2005 02:31 PM
stuck dump valve? Andrew Moore Waste Systems, Tanks & Totes 2 05-22-2005 03:01 PM
Dump valve ALANSD Waste Systems, Tanks & Totes 4 12-04-2002 06:07 PM
Dump valve gwsullivan Waste Systems, Tanks & Totes 11 05-30-2002 08:38 AM
