Old 08-11-2013, 09:08 PM   #1
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Dump Light
I discovered there is a switched light by my dump valve on my newly acquired 2008 Classic 25FB. I pushed the button and no light. So I unscrewed the fixure and removed the light. Got a 12v tester but got weird results. I then removed the small push button also and pulled all the wires out of the light fixture hole up to where the light switch and fixture are conectted to the two mail 12v line. I get 13.6v at the crimped leads but at the fixture less volts. The bulb looks to be OK. I'm thinking the switch is bad. Where can I find the the switch and the fixture if I need to replace them. I'm assuming the light isn't that functional but I'd still like it to be working.
Kelvin
Old 08-12-2013, 01:14 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
The dump light is notoriously flakey.
You can get stock replacements from any Airstream dealer.
If you're looking to upgrade to something more reliable, try the marine places. I use Jamestown Distributors for that sort of stuff.
Old 08-13-2013, 06:36 PM   #3
LFC
Memphis , Tennessee
I need to replace the switch on mine it too is flakey.
LFC is offline   Reply With Quote
Old 08-13-2013, 06:55 PM   #4
jspafford's Avatar
San Diego , California
You may find you never need it. It's not often you are likely to dump in the dark.
I just re-read that. Kinda funny.
John and Lynn,
Silvia ('06 25' Safari SE FB) and Silvester ('05 Chevy Express 3500)
jspafford is offline   Reply With Quote
Old 08-13-2013, 07:09 PM   #5
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Agreed, not many reasons or occasions to dump after sundown LEGALLY!
SeeMore is offline   Reply With Quote
Old 08-13-2013, 10:21 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I found our light was handy for night arrival connection effort. Also, enough light to unhook if leaving at night from dark location. It was useful on our last trip 2 weeks ago.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-14-2013, 12:00 AM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I replaced my sewer light switch with a heavy duty toggle switch. I later installed a red safety cover over the switch.
ID:	193153   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-13-2014, 11:18 AM   #8
KJRitchie's Avatar
2008 25' Classic
Finally got around to fixing my dump light. I replaced the switch and purchased a new bulb from an auto parts store. I chose the highest wattage bulb in that size.
I decided to go with the same switch. They are cheap so I bought a couple with extra boots. Shipping charge wasn't much.
40-2386-00 Judco Manufacturing Inc | 505PB-ND | DigiKey
Kelvin
Old 10-13-2014, 05:37 PM   #9
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I installed a rather robust rotary switch on mine. Got it at the hardware store. It has held up so far.
David
Old 10-13-2014, 05:48 PM   #10
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
There are so many things that can go wrong on with "built-ins" on an Airstream (or any other RV for that matter) that I would not sweat this one for too long. With respect to a strategy to handle a defective "dump light" for the rare occasion that it might be needed: a flashlight!
Bob Martel
WBCCI# 5766
Old 10-14-2014, 10:58 AM   #11
KJRitchie's Avatar
2008 25' Classic
I know it sounds crazy to worry about it but my Airstream is my "silver mistress" and she wanted it fixed
Kelvin
Old 10-14-2014, 11:17 AM   #12
Chelsea , Michigan
Images: 12
Kelvin
Kelvin, completely understandable!
Bob Martel
WBCCI# 5766
Old 10-14-2014, 11:37 AM   #13
Chelsea , Michigan
Images: 12
Channing, good idea about the "headlight!" I was actually thinking of clutching the flashlight in my teeth or enlisting the spouse to hold it, but your solution is much better!!
Bob Martel
WBCCI# 5766
Old 10-14-2014, 12:18 PM   #14
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
When our AS was new in 2001, I did a thorough inspection of everything and found the dump light did not work. It turned out to be a bulb with a broken filament as delivered new from the factory. A new bulb solved the problem. In the last 13+ years, I have never had a reason to actually use the dump light. However, sometimes when I'm down there pulling the valve handles to empty the holding tanks I turn on the light and cup my hand around the bulb just to make sure it still works. It does. But, it doesn't put out much light. I'd probably use my ball cap with the built-in LED lights in the visor if I was really in a situation where I had to empty the tanks in the dark.
Nomad518 is offline   Reply With Quote
