Old 12-23-2006, 10:39 PM   #1
acton
driving light gaskets???
I was checking for leaks on my 63 tradewind and noticed the riding lights front and rear dont have gaskets on them. I went to camping world thinking they will have some but was told they never came with them. i know the 3 at the rear above the rear window are leaking. I guess I will have to use some vulkem to seal them. No gaskets....sheesh
durans54 is offline   Reply With Quote
Old 12-24-2006, 05:37 AM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Yulkem sticks really well to plastics. It might make it pretty difficult to service the lights later. My 63 does not have gaskets either but I think I would cut gaskets from sheet rubber rather than glue them.
Old 12-24-2006, 08:07 AM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
If you are talking about a gasket around the plastic, I have no idea, but I bought some rubber "o" rings and stainless steel screws for my running lights. A few folks have had this issue, but mostly from the screw not the casing itself. The "o" rings seem to work.
Outlet under sink, night light LI Pets Electrical - Systems, Generators, Batteries & Solar 5 09-24-2006 05:25 PM
Hitch light plugs ALANSD Brakes & Brake Controllers 4 10-12-2002 09:04 PM
roof stack gaskets bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-25-2002 05:29 PM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 03:37 AM
Clearance light wiring Bob Evans Lights - Interior & Exterior 6 05-27-2002 11:03 AM
