Old 09-06-2014, 09:34 AM   #1
AStreamJake's Avatar
2003 25' Safari
Livingston , Texas
Do I need a resistor on my new interior LED Lights?
Hi everyone,
I just installed new LED lighting in my 2003 Airstream. Most of the lighting was Airstream's new, and much more streamlined, LED 'double pancake' lights (Airstream part # 512737). I installed these using the same wiring as my old pancake lights.
Under the front and back cabinets, I have two pancake lights wired in parallel so that I can use a single switch to cut them on and off.
My question is this - Do I need a resistor in the circuit for each of these lights and a resistor (or two) in the circuits where I've wired two lights in parallel?
Thanks for your help.
AStreamJake is offline   Reply With Quote
Old 09-06-2014, 09:48 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
If they work then you are good to go.
MICHAEL
Old 09-06-2014, 11:01 AM   #3
2003 25' Safari
Livingston , Texas
LEDs and Premature Burnout without Resistors
They do work just fine. My concern is that, in reading about LED lights, I've heard that resistors are required to limit current flow; otherwise, they burn out easily. Any electrical whizes out there that can provide me with a definitive answer about when and whether resistors are required with these type of pancake and reading lights?
Old 09-06-2014, 03:15 PM   #4
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
It's already wired in.
Ahab is offline   Reply With Quote
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
Where is the Onan R1 Resistor? swebster Mechanics Corner - Engines, Transmission & More... 17 08-12-2005 12:52 PM
Help! Resistor on fan switch Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 22 12-20-2003 08:01 AM
