Old 02-22-2012, 03:18 PM   #1
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Dimmer for LED
I just bought a four bulb LED kit from IKEA. It came with lights, an LED driver, a 120V cord with a toggle on/off switch. What I'd like to know is can I run a dimmer/on-off for these LED lights? And if so which side ( if it matters) do I add the dimmer/on-off switch
goshawks00 is offline   Reply With Quote
Old 02-23-2012, 08:34 AM   #2
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
I think the bulbs have to be designed to operate with a dimmer IIRC. Do yours indicate whether or not they will dim?
1999 28' Safari (profile selections only offers Excella in the 28)
2003 Chevy Duramax/Allison 2500HD
Yamaha EF2400is, Equalizer Hitch
AM Solar Panels
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 02-23-2012, 10:14 AM   #3
Maniacal Engineer
barts's Avatar
Menlo Park , California
This gets complicated....
LEDs are current driven devices, so need a regulator to provide the right amount of current. With common RV LED bulbs, this is built in so that the bulb/strip/whatever can be supplied with 12V. Many of these work well with
simple 12V PWM (pulse width modulated) dimmers.
Some 120V LED systems include the driver in the plug; you can generally read the output of the plug (so many volts, or so many milliamps). These will not work with a 120V dimmer unless especially designed to do so. If your bulbs need 12V, you may well be able to drive them directly w/ 12V from your batteries/converter, and you may also be able to use a 12V PWM dimmer.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 02-23-2012, 10:43 AM   #4
Zia
2011 23' FB International
Irvine , California
I have 2011 AS with LED's but does not have the dimmers, the 2012 have the dimmer added. Somebody told me that that dimmer do not save any energy. Is it true?
Zia is offline   Reply With Quote
Old 02-23-2012, 12:57 PM   #5
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
OK guys Dan @ ledrv straightened this out for me... I didn't need this kit going from 120v down to 12v. I should just use 12v. LEDs and wire them direct to a 12v source. as far as the dimmer goes... I can use a 12v dimmer. I have already returned the set back to IKEA and am going to do as Dan said and go straight to a 12v line.
Learn something new every day.
Barry
Hey Everyone! I just bought a 310 for restoration. Help needed! SteelyDan Classic Motorhomes 37 02-28-2012 12:24 AM
Labeling Interior Panels for Restoration Darin n Bet Interior Restoration Forum 8 02-27-2012 06:50 PM
Does anyone rent a vehicle for towing? Gumpdad714 Tow Vehicles 7 02-26-2012 06:11 AM
Fix for Dinette Table Wobble Road Geezer Cabinets, Counter Tops & Furnishings 7 02-25-2012 06:29 PM
Wiring for future upgrades Chuck Electrical - Systems, Generators, Batteries & Solar 14 02-25-2012 05:09 PM
