In a 1972 Tradewind, I would start with a careful disassembly and inspection of each light fixture.
You are looking for damaged wires coming through the skin and electrically compromised fixtures.
As you remove each fixture, put a wire nut on each wire.
Once all fixtures have been removed, replace the fuse.
If it does not fail reconnect each fixture one at a time until one of them blows the fuse.
If the fuse fails with all the fixtures removed and wire nuts on the wires, check the switches.
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
