Old 09-30-2010, 09:01 PM   #1
1974 25' Tradewind
Muscle Shoals , Alabama
Crazy tail light problem
On our last trip out in the 74 Tradewind, I noticed on the way home that the right tail light and brake light was out. I figured it was just a bulb problem and changed the bulb. No dice. I have tested everywhich way but loose and this is what i have discovered: The light will work when the emergency flashers are on and the key is not in the on position in the tow vehicle ignition. When the key is on, it wil do NOTHING. I checked the plug on the back of the truck and all of the connections are working there whan they are supposed to. Can anyone tell me if this is some kind of short? I have tried to remove the rear light assembly but the previous owner has stripped out the screws in an attempt to get it off. Any suggestions on how to repair this?
chuman70 is offline   Reply With Quote
Old 09-30-2010, 09:21 PM   #2
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Bad, corroded contact(s) somewhere. No or poor grounding.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 10-01-2010, 07:52 AM   #3
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Start by proofing the "Female" connector at
the TV. (Use a test light)
Next - double check the "male" plug that connects
to the TV. They do corrode, get old and worn.
If you know for sure you are getting good stuff
all they way back and into the wiring of the trailer, then
begin changing bulbs, cleaning connectors and grounds.
You must know that you are good all the way back and into
the trailer before working on the trailer.
Suggestion:
As "FrashAir" mentioned above, clean and tighten every
12V ground connection....the skin must be a good conductor
and the frame....make for yourself new skin and frame ground
connections - make em big, clean and strong - remove all doubt.
kennethowens is offline   Reply With Quote
Old 10-01-2010, 08:27 AM   #4
azfiredog300's Avatar
Surprise , Arizona
Check out what I had to do for mine.
http://www.airforums.com/forums/f447...ems-66232.html
Jerry C.
"Travelstar Galactica"
WBCCI #13317
AIR #25664
Member of the Four Corners Unit
The only true failure is the failure to try.
azfiredog300 is offline   Reply With Quote
Old 10-01-2010, 08:31 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I take it the emergency flasher lights work on the trailer when you have them turned on in the tow vehicle. Both tail lights flash? Does the left turn signal work properly? The turn signal lights are wired thru the flasher switch to inhibit the turn signal flasher from operating when the emergency flashers are on. The emergency flasher switch has sets of contacts that close when it is turn off, providing a circuit to the turn signal flasher. Try snapping the emergency flasher switch on and off while you have the right turn signal turned on. The contacts in the emergency flasher switch may just be dirty or corroded. If it doesn't work after a dozen times or so, I'd say you have a bad e flasher switch. Is it just the turn signal that doesn't work? Or is it both the turn signal and tail light? Not sure what you TV is but maybe it is set up to keep you from driving down the road with the e flashers on. Try moving the bulb around in the socket, you may be losing the tail light because of a bad connection in the socket, which is a separate contact and wire from the turn signal.
Weird Tail Light Problem mello mike Lights - Interior & Exterior 8 06-24-2009 09:36 PM
63 Globetrotter tail light problem 63air Lights - Interior & Exterior 3 09-21-2007 06:08 PM
Tail Light Always On blueline Lights - Interior & Exterior 2 05-05-2007 03:55 PM
LED Tail Light Problem wdkueser Lights - Interior & Exterior 7 09-16-2006 06:58 PM
a magical tail light Charming Wino Electrical - Systems, Generators, Batteries & Solar 5 04-03-2004 02:19 PM
