Old 12-04-2014, 06:15 PM   #1
Oroville , California
Correct adapter?
I recently purchased a 1979 airstream. I'm not sure the model because it's parked out of state. I need to move it soon.
I'm trying to identify the name of the round black hook-up that allows my vehicle to activate the brake lights and turn-signals of the airstream. I failed to take a photo. I believe the adapters called "seven blade". Am I correct that this is what it's called? Are there any variations that I need to be aware of?
My vehicle has a flat four pin.
I plan to buy the adapter at a local chain store like Pep Boys or AutoZone. Does anyone know if they carry the correct adapter?
You're some examples of what I'm asking about: https://www.google.com/search?q=trai...pping&tbm=shop
David95966 is offline   Reply With Quote
Old 12-04-2014, 06:28 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Correct adapter?
You will need the male plug that matches your TV.
Unless the trailer has been towed by a modern vehicle the chances are you will have to rewire the plug accordingly to match your TV.
The TV should have a brake controller as well.
Since you only have a 4 pin connector. You will not have brakes on your coach.
It takes a total of 6 wires to have what you need for towing.
Tail/marker lights
Brake/left turn signal
Brake/right turn signal
Common/ground
Brakes
Charge line.
The Tacoma you have in your profile is not equipped for towing a coach of that size. The 4 wire plug tells me it does not have a tow package. Without a tow package there is no transmission cooler etc.
The hitch, if there is one may not be rated for the tongue weight. Even with an equalizer.
Old 12-04-2014, 06:31 PM   #3
r carl's Avatar
Lin , Ne
Are you going to use the trailer brakes?
Old 12-04-2014, 06:43 PM   #4
I had not planned on using the brakes. It's a one time tow.
Old 12-04-2014, 07:26 PM   #5
1986 31' Sovereign
Miami , Florida
I wouldn't tow an Airstream without brakes. Especially, from "out of state".
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 01-08-2015, 11:30 PM   #6
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Inquiring minds want more details,
The tow vehicle you plan to use to recover the Airstream and how the T/V is equipped.
The size of the Airstream.
The condition of the tires and wheel bearings and brakes on the A/S.
Your in Oroville, any way you go to out of state requires going over mountains.
You will need brakes ! And a robust Tow vehicle if the A/S is over 2500 #.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Isuzu 6BDI adapter plate nscaler Mechanics Corner - Engines, Transmission & More... 0 03-18-2006 08:53 AM
Spedo cable adapter. SebastianD Airstream Motorhome Forums 1 09-14-2003 06:07 PM
Handfree Cellphone Adapter Krazykraut Off Topic Forum 4 02-18-2003 02:48 PM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
Adapter / Electric from garage? bkpine Electrical - Systems, Generators, Batteries & Solar 8 08-13-2002 08:22 PM
