Old 10-17-2011, 10:59 AM   #1
1967 22' Safari
Stevens , Pennsylvania
Copper Wire?
I stripped out all the aluminum wire from my 67 Safari. Is there any reason not to re-wire with copper?
Evets is offline   Reply With Quote
Old 10-17-2011, 11:15 AM   #2
dznf0g's Avatar
Oswego , Illinois
Definitely use copper.
Old 10-17-2011, 11:17 AM   #3
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Aluminium boat owners don't like copper.
As long as you don't expose copper directly to the aluminium, I would think it is OK.
http://www.duroboat.com/experience/A...Corrossion.htm
Use alumium terminals for all ground connections to aluminium.
They are easier to change than the aluminium channel frame.
"It must not be based on a dissimilar metal. copper is particularly problematic. Side note: Copper pennies, copper shell casings, heavy copper wire used as fish clubs have all been known to be starting points for corrosion if left in the bottom of an aluminum boat."
"When corrosion is at work metal actually leaves the least noble metal in any circuit and deposits itself on the most noble metal. Aluminum is low on the nobility tables so it will give itself up if it is in a salt solution near a more noble metal and there is electrical activity (natural or man made) present. "
Dave
Old 10-17-2011, 04:48 PM   #4
Kevin245's Avatar
Hi Evets,
Here's a thread on the subject. IIWM and the aluminum was already stripped out I'd definitely go back with copper.
Replace Aluminum wiring? - Airstream Forums
Kevin
Eleanor Roosevelt
Old 10-17-2011, 08:07 PM   #5
1967 22' Safari
Thanks guys! Sounds good to me!
Old 10-17-2011, 08:21 PM   #6
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Copper - easy to obtain at home improvement stores, cheeper, DIY friendly.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 10-19-2011, 11:05 AM   #7
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Rewired mine with copper BECAUSE it was aluminum.
SilverHoot is offline   Reply With Quote
Old 10-19-2011, 02:53 PM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Copper is a better conductor and doesn't "creep" (loosen) like aluminum at its connections. I don't believe aluminum is legal in residential installations, if that tells you anything about it as a conductor.
doug k
1988 Running Light Exposed Wire vhariable Lights - Interior & Exterior 2 06-25-2011 08:56 PM
Where does this heavy black wire go? malconium Electrical - Systems, Generators, Batteries & Solar 3 05-31-2011 01:07 PM
One Wire Running Lights---Effects on Grounding tinbender Lights - Interior & Exterior 7 04-18-2011 07:22 AM
Burnt wire on my univolt MonaxLisa Batteries, Univolts, Converters & Inverters 11 03-23-2011 12:31 PM
Running Lights LED - How do I route the wire? AirHome Lights - Interior & Exterior 6 02-20-2011 07:15 PM
