I have progressed to the next stage of my full restoration and and procrastinating because I am unsure of a couple of things.
I have the converter working fine and ran some wiring for the 12 v lighting system. Then it dawned on me, how can I control multiple lights with there own switches on one circuit and be able ot always have power to the lights regardless of the previous switches off position? Make sense? In other words, if i have two lights on a circuit each with its own switch how can I maintain power to the second light on the daisy chain even if the switch for the first light is in the of position.
A real example is I have the two overhead sleeping area overhead lights on the same circuit with the bathroom. if the sleeping area light switch is off, how do I get power to the bathroom?
The limited home wire experience I have tells me to have a junction box and run a hot to the bathroom light but I am not familiar with this approach for a
12v system. Any thoughts men?
Currently, here are my thoughts for my
12v system:
1. 2 front end cap lights and 2 bunk lights (1 over each bunk) with a switch or the front end cap lights and two individual switches for each bunk light.
2. 3 center lights lights and a bathroom light each with separate switches
3. 1 circuit for some
12v outlets and all of the storage lighting under the two bunks and the under dinette seating each with there own switches on the fixture itself.
4. 1 circuit for the led tape lighting to illuminate the outer walls circumference, under each on the bunk overhead cabinets, each of the kitchen galley cabinets and the from endcap cabinet area. The thought for this lighting is to put it on a dimmer so that when all lighting is off, i can set a very soft light around the circumference of the trailer.
What do you gentlemen think about this for the 12v lighting?
