Old 01-31-2016, 12:23 PM   #1
1997 30' Excella
Corpus Christi , Texas
Connecting marker lights
Two wires come out of trailer- do I need to solder them to new marker light? One to each light?
Knudsvig is offline   Reply With Quote
Old 01-31-2016, 12:31 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Lets clear one thing up first. You say 2 wires. Marker lights are commonly 1 wire and grounded directly to the trailer skin.
If you are using LED lights and there are in fact 2 wires the lights are polarity sensitive.
How about a picture before we go much further.
2004 Excursion 4x4
Old 01-31-2016, 01:14 PM   #3
1997 30' Excella
Name:	ImageUploadedByAirstream Forums1454271273.328997.jpg
Old 01-31-2016, 03:21 PM   #4
HowieE's Avatar
Images: 12
looks like they may have daisy chained the marker lights. if when you removed the old light all 3 wires were connected together that is the case.
To test it out. Turn the parking lights on. Are any of the marker lights to the rear of this light lit? If not I think they are daisy chained. if you have a 5 amp fuse use it to touch the 2 wires coming out of the trailer together. While this is in place do the marker lights to the rear of this light come on. If so discard the fuse and connect all 3 wires together and you should be done.
2004 Excursion 4x4
Old 01-31-2016, 04:43 PM   #5
1998 30' Excella 1000
Livingston , Texas
My '98 has two wires coming out of the grommet also. My replacement fixture came with two wires. Is that your new fixture (post #3)? Maybe they were expecting you to use the metal plate/screw to complete the curcuit. Can't tell from the photo. You could use your voltmeter to check for continuity.
Siegmann is offline   Reply With Quote
Old 01-31-2016, 06:13 PM   #6
1997 30' Excella
This is the new one. The old one had these two wires soldered to the metal connectors by the bulbs
Old 01-31-2016, 06:22 PM   #7
Livingston , Texas
I can't see the left side, but it looks like the new one has only one wire? If so, as noted before, use a voltmeter to test for continuity from that wire to another location on the fixture.
Anyone know of LEDs for the rear marker lights on mid '70s on the tail lights? Mixter Lights - Interior & Exterior 8 11-11-2014 08:27 PM
Running marker / clearance lights unhooked Kistler Electrical - Systems, Generators, Batteries & Solar 19 12-18-2006 07:30 PM
marker lights dont work wb13798 Mechanics Corner - Engines, Transmission & More... 6 11-09-2002 11:40 AM
marker lights bhsl8 Lights - Interior & Exterior 6 09-12-2002 06:01 AM
