Old 12-09-2012, 05:29 PM   #1
Razorhog's Avatar
1974 27' Overlander
2015 28' International
Little Rock , Arkansas
Combination ceiling light / vent assembly parts 1974 International
I am restoring a 1974 Airstream 27-ft International and looking for replacement shades for the combination ceiling light and vent assembly. The part number in the service manual is 08517. It is 18" x 18.5".
Also, I need one fan crank, part number 02255.
Does anyone have a source?
Name:	light shade.JPG
Razorhog is offline   Reply With Quote
Old 12-09-2012, 06:22 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Those parts are still available from Airstream, so any dealer should be able to get them for you, if they don't have them in stock.
Old 12-09-2012, 06:26 PM   #3
1974 Argosy 20
Kooskia , Idaho
Inland RV part number 65231 $13.95
Inland RV Center - The Nations Leading Expert in Airstream Innovations
If you are not familiar with Inland RV, start with the above link and look at their parts catalog. That is where I found the above information. Lots of other good stuff there too.
Old 12-09-2012, 09:02 PM   #4
1994 30' Excella
Mississauga , Ontario
Another source would be Out-of-Doors mart. They are on the East coast.
Al
Al and Jean
TAC ON-3
Old 12-09-2012, 09:32 PM   #5
Roblin , MB.
Hi,
Almost finished our '74 A/S International 31' restoration.
We purchased light covers and they are worth every penny.
While you are doing the new cover resto - you should consider converting your original incadescent bulbs to Led's. We did that for the 3 celing lights like yours, kitchen, hallway, bathroom and outside scare light. You wouldn't believe how bright the lighting is now. You can contact Dan Brown at Dan@led4rv.com and he will help you with the conversion.
nairnchyz is offline   Reply With Quote
Old 02-08-2013, 09:29 AM   #6
Jim & Mitzi's Avatar
1990 34' Excella
1990 29' Land Yacht
Americus , Also Valrico, Fl
1977 square ceiling light covers
Bought 3 new covers and for some reason, it seems too thick ??? I am not able to raise it enough for the vent crank rod to protrude thru the new cover. The light switch can be convinced to get into its place. As similar experiences? Many Thanx
Jim & Mitzi is offline   Reply With Quote
Old 02-08-2013, 10:04 AM   #7
Assuming that you bought those from an Airstream dealer, the mold that made the original lenses is still in use today.
The lift arm part does not have to protrude thru the lens in order to work properly.
Old 03-12-2013, 07:07 AM   #8
lewishw's Avatar
1978 31' Sovereign
Colorado Springs , Colorado
My '78 sovereign has the more basic light covers like the one in this photo:
Are the lenses you are talking about interchangeable with the ones I have?
If so, do I need to mount them with rivets or do the light switch and vent crank just hold them in place?
Thanks for the info guys!
Hunter
lewishw is offline   Reply With Quote
Old 03-12-2013, 07:42 AM   #9
Ottawa , ON
Lewis, those are not the same as what the '72 to '77 models use.
Out-Of-Door Mart in NC has them too.
Airstream Ceiling Light Lens 201154 Airstream Light Lens 1972 1977 [201154] - $14.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Old 03-12-2013, 08:44 AM   #10
Sorry Aage, but the lenses changed in 1978.
the 77 and 78 are not interchangeable.
Old 03-12-2013, 03:43 PM   #11
Ottawa , ON
Thanks for the correction, Andy.
Old 03-15-2013, 10:48 AM   #12
Razorhog's Avatar
1974 27' Overlander
Jim and Mitzi: The holes in the new covers did not line up quite right so I was able to drill them a tad bigger allowing the cover to raise more.
Old 03-15-2013, 12:39 PM   #13
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Images: 32
Actually neither. You mount them with screws. They need to be removable to change the bulbs or fluorescent tubes, depending on which you have. Either way, you don't want them riveted in place. Too much regular maintenance needed.
Vaughan
Old 03-15-2013, 01:12 PM   #14
The 72 to 77 ceiling light lens, was never mounted with screws.
One end is held in place with the lift handle and the other end is held in place with the light switch nut.
