Old 09-30-2011, 02:07 PM   #15
flyingcloud's Avatar
2012 27' Flying Cloud
somewhere , on the road
Images: 8
Originally Posted by tpi View Post
One thing I would do, regardless of outcome is call Airstream and ask if there are any warm white (2700-3000K) LEDs available for the fixtures. Somehow send a signal that you're not happy with the color temp of the factory lamps.
That was the first thing we did! Still waiting on my latest order to arrive - I'll let you all know if it worked, or not - then I'll have to try some of these suggestions. Thanks everyone. For now, our trailer is called "The Blue Light Special."
Our blog: Aluminarium
Find & Share Great Campsites: Campendium
flyingcloud is offline   Reply With Quote
Old 09-30-2011, 02:30 PM   #16
Eric H's Avatar
1974 23' Safari
1947 25' Spartan , Manor
Hi there,
I light for film and TV and we use gels all the time to change the color of lights.
You will want to use CTO (Color Temperature Orange) or something similar. "Straw" is quite nice too.
If you pick up one of these: Lee Swatch Book - Get One Free With Purchase - Filmtools
You can test all sorts of gels (just cover the others with tape). You will most likely use a 1/4 straw or CTO or maybe 1/2, just remember that this will cut your light transmission rate.
I would also suggest sandwiching in some "minus green gel" (it will be slightly red) maybe 1/8 Minus Green as the LEDs have a bit of green in them.
I know LEDs don't run very hot, but if the gels are placed right up against them the heat (even the little bit) will eventually take the colors out of the gels and you will need to replace them.
Lighting Gel Sheets - Filmtools
Hope this helps.
Eric
Eric H is offline   Reply With Quote
Old 09-30-2011, 02:35 PM   #17
Eric H's Avatar
1974 23' Safari
Ha! just read that the other Erik posted the same thing!!
Old 09-30-2011, 02:41 PM   #18
Images: 8
Thanks Eric (and Erik) - I think a swatchbook is just what I need, plus some minus green.
Old 10-08-2011, 08:47 AM   #19
Images: 8
Smile Fixed!
Originally Posted by flyingcloud View Post
I just ordered one that's more pink and if it works I'll post a link to the exact gel I ordered.
It worked! I wrote a post on my blog about it: http://www.aluminarium.com/airstream/airstream-led-color
Old 10-09-2011, 08:39 AM   #20
Eric H's Avatar
1974 23' Safari
Glad to see it worked! The pink spike is giving ya that minus green effect in one gel so that's a great find.
In the restoration of my 74 Safari I was planning on using warm LEDs strips, but have recently thought about side light fiber optics with LED generators... Perhaps that's my next thread:-)
Cheers.
Old 10-09-2011, 09:46 AM   #21
1965 22' Safari
East Islip , New York
Nice solution for sure.
Looks like surface mount LED's inside the puck. Not easy to replace the actual LED's, so yours is definitely the better option.
-Hans
HHaase is offline   Reply With Quote
Old 05-25-2012, 06:49 PM   #22
Hoonanea's Avatar
2012 23' International
Riverview , Florida
I just want to add my thumbs-up to this thread. I found it a couple of weeks ago and ordered my filters/gels through Filmtools.com. Just finished adding the Straw and Minus Green to all of the LEDs. What a difference. It's so much less intense than the harsh bright white and blue overtones. Very happy with the results! Thanks to everyone who contributed to the thread.
Here's what I ordered -- haven't yet used the Orange (CTO):
Lee Filters: Gel Sheet 124
205 1/2 C.T. Orange (CTO)
Lee Filters: Gel Sheet 178
279 1/8 Minus Green
Lee Filters: Gel Sheet 205
442 Half C.T. Straw
Ho'onanea -- to pass the time with peace, ease, and pleasure.
Hoonanea is offline   Reply With Quote
Old 05-25-2012, 09:07 PM   #23
Eric H's Avatar
1974 23' Safari
Great! Glad it worked!
I'm re wiring and putting in 6 strips of these warm white leds (16 foot strips x 6) all on dimmers.
http://www.amazon.com/Flexible-LED-R...8001440&sr=8-1
Should make a nice office / work space.
If you want to replace LEDs with warm, pleasant versions just look for the 3200K (kelvin) or below. 2700K is pretty warm, but should be very nice.
Old 05-25-2012, 09:13 PM   #24
Eric H's Avatar
1974 23' Safari
279 1/8 Minus Green
442 Half C.T. Straw
One additional word of wisdom: roll up the remaining part of the filter and put them in a closet somewhere. Eventually the UV in the LED will make the color in the filter fade and you will need to replace them.
Cheers!
Old 08-21-2014, 08:24 PM   #25
asianmack's Avatar
2011 19' Flying Cloud
Chicago , Illinois
I want to thank everyone on the thread here that shared advice about lighting gels.
We wanted to warm up the reading lights on both the front and the back of our trailer. I don't mind the ceiling lights being cool and bright, but when we're getting ready for bed or want to read we wanted a warmer glow. Here's what I did:
Before picture of the reading light with cool blue LED.
Cutting out the Rosco Cinegel #3407 Filter - RoscoSun CTO - 20x24" Sheet (only $6.50 from B&H Photo).
I know the gel looks very orange, but when the LED is shining through it'll be more washed out.
Putting the cut gel into the cap for the reading light.
The final result. The LED looks like an incandescent light bulb now.
Thanks again for all the tips here. It's what makes this site great.
Airstates, a better brag board. Beautiful adventure checklist for your travel trailer. http://airstates.com
asianmack is offline   Reply With Quote
Old 08-22-2014, 07:37 AM   #26
Erik Olson's Avatar
1974 29' Ambassador
CONCORD , North Carolina
Images: 20
Send a message via Skype™ to Erik Olson
I recommend cutting several spares out of the excess gel, because we're finding that the LED emitters, which do not emit appreciable IR, UV or heat, are burning holes right through the color layer on the gel.
This isn't dangerous in any way, but you will notice (after about a month of cumulative runtime) that the color in front of each emitter will be completely burned to clear.
For about $8.50 each, I have Rosco's "PermaColor" dichroic glass in these same gel colors. We just need to know the diameter of the desired lens (the size you're cutting the temporary gel product) and then you'll have a permanent solution.
If anyone is interested in high CRI 2700-3000K LED tape, I have a good supplier through my vendor, American Lighting. They offer dimmable Bright White (which is close to daylight 5000K); Warm White (3000K, which is really close to halogen); and Ultra Warm White (2700K, like table lamp color).
They come in a basic kit, and we can also provide L or T connectors, plug-in power supply or permanent install 12V power supplies. I'll post up some pictures of some in my rig next week!
http://www.americanlighting.com/assets/led_flexform.pdf
And, for West Coasters, FilmTools is nifty. For the rest of the country (and World), you want to call me! eolson@barbizon.com www.barbizon.com
Cheers,
e
Erik Olson
1974 Ambassador 29' Ohana
www.tradingpathmedia.com
Erik Olson is offline   Reply With Quote
Old 08-22-2014, 08:34 AM   #27
Images: 8
Looks great!!
Old 08-22-2014, 10:13 PM   #28
Eric H's Avatar
1974 23' Safari
Led cri
Hey Eric,
when you say high CRI, how how are we talking?
I wouldn't want to put anything below 95CRI in my living area, are they that high? Are they high output?
Cheers,
Eric
Cheers,
e
LED lighting retrofit for interior lights Westfalia Lights - Interior & Exterior 372 12-17-2016 11:43 AM
LED Conversions klattu Classic Motorhomes 76 01-18-2013 05:31 AM
LEDs to replace Fluorescents Wingeezer Lights - Interior & Exterior 16 08-16-2011 10:44 PM
New LEDs cause radio / TV interference polarlyse Lights - Interior & Exterior 5 08-05-2011 07:57 PM
Looking for LED's RV Airstream , some asking John H. Exterior Restoration Forum 0 04-19-2011 09:15 AM
