Old 10-02-2016, 12:10 PM   #1
Tiger Tail's Avatar
1986 31' Sovereign
Jacksonville , Florida
Clearance lights won't come on.
I've replaced all my red (rear) clearance lights and now none will come on. The tag light included. I noticed as I was looking at the side amber light it went dim then off. Truck relay is good.
Tiger Tail is offline   Reply With Quote
Old 10-02-2016, 12:15 PM   #2
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Initial wild guess is that the lights aren't properly grounded. Some use the screw that holds them to the trailer skin, and some use other systems. There's got to be a proper contact between the negative side of the light circuit and the metal shell of the trailer.
Best of luck.
mimiandrews is online now   Reply With Quote
Old 10-02-2016, 01:42 PM   #3
millertimeUS's Avatar
1976 25' Tradewind
Second on the bad ground, my new clearance lights had the same issue. I used a larger stainless screw (was using the same old holes and screw size previously). They all work 100 percent after that.
76 'Airstream Tradewind
Matt
millertimeUS is offline   Reply With Quote
Old 10-02-2016, 02:41 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
I do not buy the ground theory. Each light is grounded separately to the body. Only if the body to chassis connection was bad would it cause all to go out.
If the amber lights came on and then went dim and then out I would look for a short in one of the new lights after disconnecting the umbilical cord and checking the fuse in the TV.
The feed to the marker lights is common feeding from the front to rear of the trailer. If you find a short and correct it all lights should then work. That is assuming you only have one short.
2004 Excursion 4x4
Old 10-02-2016, 02:54 PM   #5
1991 25' Excella
Stanfield , Oregon
If there leds did you hook them up backwards?
SpletKay06 is offline   Reply With Quote
Old 10-02-2016, 02:57 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
That is a definite possibility. They are polarity sensitive.
MICHAEL
Old 10-02-2016, 03:26 PM   #7
Tiger Tail's Avatar
1986 31' Sovereign
Incandescent only
Old 10-02-2016, 03:44 PM   #8
Tiger Tail's Avatar
1986 31' Sovereign
Is the tail / clearance lighting wired through the 12 volt breaker box in the A/S?
Old 10-02-2016, 04:45 PM   #9
Tiger Tail's Avatar
1986 31' Sovereign
Awww SNAP! I missed it first time around no power at trucks plug meant blown fuse. I was swapping relays. It's fixed now, thanks for your inputs.
Old 10-03-2016, 12:32 PM   #10
2000 30' Excella
Toledo , Ohio
I had one hot wire touching the body on mine when I changed and it kept blowing the fuse in my truck drove me nuts until I found it
woodfox45 is offline   Reply With Quote
Old 10-03-2016, 02:49 PM   #11
Tiger Tail's Avatar
1986 31' Sovereign
Sounds like me too
Old 10-03-2016, 09:20 PM   #12
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
Im betting on ground as well ...when I Reno'd mine I ran a ground line to all my lights/etc... everything ran to a buzz bar (by the fuse box) grounded to the frame...as well as screwing everything to the body...i know I'm grounded!!,...LOL... ...Bad grounds are probably the cause of a majority of "weird electrical problems".
rucos is offline   Reply With Quote
Old 10-04-2016, 01:26 AM   #13
1974 Argosy 26
Duncan , British Columbia
maybe trailer ground, I had a similar situation and found that a ground wire was very badly corroded Regards Toney, hopefully you will find the challenge
kilonot is offline   Reply With Quote
Clearance clearance LEDs mayco Classic Motorhomes 55 04-29-2016 04:41 PM
Open House!!! Come one come all!!! wheel interested Photography 248 08-21-2012 08:32 AM
chat, come one come all! john hd Off Topic Forum 13 01-25-2005 06:51 PM
Front Right Jack Won't Come Down swebster Mechanics Corner - Engines, Transmission & More... 8 01-17-2004 08:03 AM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
