Old 06-08-2013, 11:15 AM   #1
Very american 4 a french
brunoffrance's Avatar
1971 27' Overlander
DUNKERQUE / FRANCE , Nord
Images: 68
Clearance lights when parking
Hi the community,
I've seen some of you , with clearence lights on when you're parked in campgrounds and , with the 110 v plugged.... In the night, that looks great and I want to do the same without destroy the A/S electricity ....
They/you connect a wire between two plugs in front of the trailer so what is the good connection for that .
Thank you in advance....
bruno.
My blog:The american dream in FRANCE:
My pictures in high quality: Pictures on FLICKR:
My videos are on YOU TUBE
My AIRSTREAMLIFE ning
brunoffrance is offline   Reply With Quote
Old 06-08-2013, 11:37 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Bruno, connect the two top connections on the 7 pin plug together with a 16 gauge wire and two spade connectors.
If you want to be cautious, you can wire in a 10 amp fuse to the wire, just in case.
Old 06-08-2013, 12:22 PM   #3
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Some of us have made their own switch assembly that plugs into the trailer plug for this. There is also some out there to buy that do this. Doing a search on here might bring it up as it has been mentioned on here already.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 06-08-2013, 12:24 PM   #4
1974 Argosy 20
Kooskia , Idaho
Or buy an extra car end outlet and bridge the top two wire connections (ones closest to the locator pin) with a fuse and plug it in when you are wanting to have the lights on.
Old 06-08-2013, 12:24 PM   #5
richinny's Avatar
2011 34' Classic
hi bruno :-)
i like the idea of a fuse connection. add spade terminals to somehing like this: http://www.sunstore.co.uk/images/P/In-line%20fuse.jpg
Ricky
Old 06-08-2013, 02:51 PM   #6
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
Hi bruno!!!!
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 06-08-2013, 03:32 PM   #7
2004 30' Classic
Roseville , California
Hello Bruno:
If you use the clearance lights when parked, our group of Airstreams refer to these as "party lights" and yes we do get others asking us how to do this. There is a manufacturer of a "plug-in" device that does this with a switch for 0-1 operation and a 10 A fuse. I've even seen plug-ins with flasher device but that can be irritating even after a few minutes!
If you have not changed ALL your clearance lights from incandescent to LED you should do that as well. I measured 8.4 A DC through the 7-pin trailer plug on our trailer with the incandescent bulbs and then switched over to LED's. After I measured current of 0.84A DC or a 90% reduction in amps. Your converter will like the lower power load as well.
The only bad thing about LED's is they don't like water or moisture inside the lens. We're in central California where it is 42 C here today and we only have a few months of rain. But if the LED's get soaked they will drop in brightness. I'd suggest sealing the lens to the fixture around the top of the lens with a clear sealant with a small vent hole in the bottom of the lens to fixture. Incandescents can burn off moisture from their heat but since the LED's have no heat, moisture can be a problem. Since the life of these bulbs is 25,000 hours, I doubt you'll be changing these bulbs in your lifetime.
Paul
tinearpaul is offline   Reply With Quote
Old 06-08-2013, 03:42 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
You can "pot" LEDs in epoxy and run them submerged if you want. Use dielectric grease on bulb connector for good connection.
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 06-08-2013, 06:13 PM   #9
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Running the clearance lights while camping is a cool idea! I've never seen it, but I like it.
Old 06-09-2013, 12:56 AM   #10
1971 27' Overlander
Images: 68
hi there,
Thank you for all replis you've done so which pins ( two I suppose) are to be connected together to get the clearance lognts on ?
My trailer has always the genuine 7 pins "male" connector from 1971....
bruno.
Old 06-09-2013, 02:25 AM   #11
richinny's Avatar
2011 34' Classic
is this what you have?
http://www.airforums.com/forums/f447...ing-20279.html
remember that if the diagram you look at is for the tow vehicle end, the wires will be reversed. if you use a test light on the trailer end use the 12 volt hot pin as a reference to the diagram.
Ricky
Old 06-09-2013, 06:47 AM   #12
1971 27' Overlander
Images: 68
Yes, it's the same one ....
Simply I have to connect the clearance / road lights with which other one ???
bruno.
Old 06-09-2013, 07:05 AM   #13
2003 25' Safari
Riverside , California
The Batt feed ckt
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
Bob4x4 is offline   Reply With Quote
Old 06-09-2013, 07:27 AM   #14
Well Preserved
1993 21' Sovereign
bruno.
Bruno, looking at the connector plug on your trailer, the two top pins get connected. That is the two closest to the "barb" that slides in the top of the plug. Battery + and running lights.
Clearance lights chrischarles Lights - Interior & Exterior 3 02-01-2012 01:55 PM
Top clearance lights on 13 panel whale tail? Sugarfoot Lights - Interior & Exterior 17 08-28-2011 04:01 PM
Electrical issues with clearance lights 1987_345 Classic Motorhomes 13 08-25-2011 08:13 AM
Clearance lights issue jsprad Lights - Interior & Exterior 3 08-20-2011 09:28 AM
Replace clearance lights Okiegent Lights - Interior & Exterior 0 03-04-2011 08:43 PM
