Old 06-13-2008, 10:31 AM   #1
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Clearance Lights, What Color?
So are the rear 5 red and the front 5 yellow? Going out to buy new and as mine have no lens any more, this would be good to know.
Old 06-13-2008, 10:38 AM   #2
The rear clearance lights are red and the front's are amber.
Since your replacing them, you might consider using LED clearance lights.
Granted they cost more, but they are brighter in the daylight than the originals are at night time.
Same is true for the tail lights.
Old 06-13-2008, 10:53 AM   #3
Aerowood's Avatar
Arvada , Colorado
That's the current plan, Thanks
Old 06-13-2008, 01:20 PM   #4
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Areow00d
5 amber in the front and I just have three(3) Red markers in the rear plus tail-lites . I just replaced all of them at a cost of $1.95 each. I did replace the originals which were Signal-Stat with Grote. The old just crumbled when trying to replace bulbs.Thus the decision to totally replace them all.New lites come with no gaskets as the old had but have ample drainage and I just caulked the screw and wire holes well before reassembly.
Roger
Mikethefixit is offline   Reply With Quote
Old 06-13-2008, 02:11 PM   #5
timkim's Avatar
1972 25' Tradewind
Gualala , California
Images: 8
attaching running lights
Aerowood, I just removed all my running lights: 5 amber in front and 5 red in back. When I removed them all the screws were rusted. Some had been exposed to water and the elements some hadn't. Should I consider using an aluminum or stainless steel screw to attach the new ones? Or will regular sheet metal screws work? It looks like HD has both aluminum and stainless screws that would work. I just don't want the new ones to rust out and then I am also trying to relate to the earlier conversation about mixing metals. I don't want to put the wrong screws in.
Thanks, Tim K.
Tim K
AIR #25767
timkim is offline   Reply With Quote
Old 06-13-2008, 03:05 PM   #6
Aerowood's Avatar
Arvada , Colorado
Either SS or AL will work, but I would lean toward the SS
Old 06-13-2008, 03:45 PM   #7
timkim's Avatar
1972 25' Tradewind
Images: 8
Thanks, I am assuming SS for the strength, and if that is correct that's the way I will go.
BTW I have been following your full monte, absolutely beautiful work.
Tim K.
Tim K
AIR #25767
Old 06-13-2008, 08:40 PM   #8
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I ordered a whole bunch of SS screws at Bolt Depot - Nuts and Bolts, Screws and Fasteners online. Very reasonable.
Vaughan
Clearance Lights For 76 Argosy Gkiesel Lights - Interior & Exterior 3 04-23-2007 03:55 PM
Clearance lights get dim? Chopper Electrical - Systems, Generators, Batteries & Solar 6 09-25-2006 10:37 AM
Front Clearance Lights Chaplain Kent Classic Motorhomes 2 07-13-2006 10:29 AM
Clearance lights fogging cammur Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 03-01-2006 09:09 PM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
