Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 07-13-2003, 07:52 PM   #1
Cruiser
Cruiser's Avatar
Profile:  1952 25' Cruiser
Brattleboro , Vermont
Images: 49
clearance lights not sealed?
The clearance lights on our "52 Cruiser have an aluminum plate with teardrop lenses. There is no sealant or gasket between the lens and the plate; does anyone know if this is how they were designed?
If it's not supposed to be this way, what can I do to get a good seal?
Doug
Cruiser is offline   Reply With Quote
Old 07-13-2003, 08:10 PM   #2
Ken J
Profile:  1958 26' Overlander
Tijeras , New Mexico
Doug
On mine there was nothing between the plate and the lense - but I did put vulkem between the plate and the trailer.
Ken J.
Ken J is offline   Reply With Quote
Old 11-03-2003, 03:53 PM   #3
rluhr
Commercial Vendor
rluhr's Avatar
Profile:  1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Leaks resulting?
I am chasing down a few leaks in my trailer. The current suspect is the clearance lights (I've eliminated nearly everything else). The water leak appears in the trailer along an interior wall seam just forward of the streetside windows, along the hinges of the windows, and along the top edge of the rear (bath) window.
For a long time I thought the windows themselves were leaking along the hinges (and perhaps they are). But I think it's more likely the water is coming in from above, and just appearing when it hits the windows.
So, is there a technique or procedure for absolutely positively sealing clearance lights?
-- RL
rluhr is offline   Reply With Quote
Old 11-03-2003, 04:23 PM   #4
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
I noticed that there was not sealant on the marker lights as well.
I removed them all and intened to replace them with my new led marker lights.
I will be putting a small bead of vulkem across the top of each screw hole and where the wire comes thorugh the body of the trailer. All this will be underneath the marker light so no sealant will be seen when I am finished.
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Bulbs - Tail and Clearance Zed2 Lights - Interior & Exterior 3 07-13-2005 12:53 PM
Running Lights Barkingspider Lights - Interior & Exterior 7 12-11-2003 09:48 PM
Rear Indicator Lights Cracker Lights - Interior & Exterior 7 11-03-2003 03:42 PM
running lights mazda997 Electrical - Systems, Generators, Batteries & Solar 0 08-27-2003 09:55 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 07:43 PM
