Old 07-18-2016, 02:04 PM   #1
2000 30' Excella
Toledo , Ohio
Clearance Lights help
My rear upper clearance lights aren't working all the bulbs are good where does the wires start from ? It's a 2000 Excella 30' abybody have any ideas where to look ?
woodfox45 is offline   Reply With Quote
Old 07-18-2016, 10:39 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
On my 1999, I found the wiring connection in the street side of the rear storage compartment. I found it in the schematics which shipped with the Airstream.
Do you have power at the fixture?
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-19-2016, 05:23 PM   #3
2000 30' Excella
Toledo , Ohio
No power to the lights it was too hot today to work on it I hope I can get at it early in the morning and remove the lights and try to see what is going on . It has the rear queen bed so there isn't any access to the rear without tearing things apart .
Old 07-19-2016, 10:15 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Maybe I Am wrong.. But it was I also have the rear queen arrangement. Nothing had to be disassembled... I have commitments tomorrow but can take a pic... If you have the schematic you can easily trace your layout.... All I had to do was disconnect the connector then reseat...
Problem fixed.
my memory can be fickle... So sorry no perfect answer.. But don't lose hope!!
Channing
WBCCI# 30676
Old 07-20-2016, 04:54 AM   #5
2000 30' Excella
Toledo , Ohio
Problem fixed.
Thanks I will try the disconnect and reseat it first before I remove the lights .
Old 07-20-2016, 10:37 AM   #6
2000 30' Excella
Toledo , Ohio
I checked the connector and have power out of the connector and nothing to the lights , Tried to remove one and there is hardly no wire coming out of the body it's so short you can't get anything attached to it to test it .
Clearance clearance LEDs mayco Classic Motorhomes 55 04-29-2016 04:41 PM
Running marker / clearance lights unhooked Kistler Electrical - Systems, Generators, Batteries & Solar 19 12-18-2006 07:30 PM
clearance lights not sealed? Cruiser Lights - Interior & Exterior 3 11-03-2003 03:23 PM
LED Clearance/Marker lights Safari Tim Lights - Interior & Exterior 13 10-24-2003 09:54 PM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
