Old 09-11-2008, 05:41 PM   #1
Alumanutz's Avatar
1966 22' Safari
Chico , California
Circuit Breakers
I have started sorting out my electrical system on my 1966 Safari. When I opened up the junction box in the front I found a circuit breaker riveted to the cover. Is this stock? I know there are three breakers in the back for inside. Is there a way to test these breakers or should they just be replaced? On the internet they are only a few bucks. I would just need to figure out the amperage rating. Any thoughts?
NUTZ
Alumanutz is offline   Reply With Quote
Old 09-11-2008, 08:02 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The current rating of a circuit breaker is usually stamped in the top of the switch handle itself. If not there when you remove the breaker the part number and rating should be on the side.
As for a breaker riveted to the cover of the panel that sounds like an after thought.
If you want to test a breaker just apply a load that is at least 90% of the rating. Breakers are designed to trip at 80% of rating. A toaster and a hair dryer is a crude way but should trip a 20 amp breaker.
2004 Excursion 4x4
Circuit Breakers Tripping bgarver Electrical - Systems, Generators, Batteries & Solar 2 11-16-2007 10:52 PM
70 amp breakers livexl Classic Motorhomes 0 03-07-2006 07:21 PM
Circuit breakers,94 33ft Motor Yacht rayschell Batteries, Univolts, Converters & Inverters 4 07-10-2005 11:35 AM
**Circuit Trouble** Silvertwinky Electrical - Systems, Generators, Batteries & Solar 1 06-30-2004 07:32 PM
Electric Heaters Tripping Circuit Breakers streamlean General Motorhome Topics 11 01-20-2004 09:29 PM
