Old 03-04-2010, 12:26 PM   #1
Wise Elder
Jammer's Avatar
2010 30' Classic
Chmsl
Has anyone installed a CHMSL (center high mounted stop light, aka "cyclops") on the 'stream? I was pondering the possibility and any reduced chances of a rear end collision.
Old 03-04-2010, 02:09 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
My 2008 Star Stream came with one. It's an LED light, and it runs off the brake control circuit. I've thought about putting one on Little Girl, above the rear window when we re-do the wiring and convert all all the outside running lights to LEDs. I personally think anything that increases braking lumens is a good idea.
Chris
Old 03-04-2010, 03:50 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Volley. Your court.
Running wire for such an effort would be a bear.
Vintage owners, during a reconstruction effort, would obviously have an easier time since most times the furnishings/wall skins have been removed.
Such a light would obviously give more notice to others of your braking.
Should you decide to go with the installation of one, do you plan to add it yourself, or ask Airstream to do it?
Tom
Old 03-04-2010, 04:18 PM   #4
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
The whole idea of the higher single light was so you could be seen sooner over the crest of a hill. The inital tests were done with taxis & police cars. They had the extra turn signals/brake lights mounted on the rear deck of 4 door vehicles. I'll always drive with my lights on. Even in the daytime. The rear clearance lights will announce my presence over a hill crest in the dark hours.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 03-05-2010, 09:36 AM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Yes, the wiring would be problematic.
I thought one of the initial experiments was on post office vehicles.
I note that medium duty and larger trucks don't have them. Maybe with the extra height and the prominence lights they aren't necessary, on trucks or on an Airstream.
Old 03-05-2010, 10:15 AM   #6
_
we've had other threads on this issue...
http://www.airforums.com/forums/f447...eam-45112.html
and related things.
wiring isn't a big issue...
the high center brake lite can be tied into the existing trailer tail light wiring easily.
i had PLANNED to add this feature too, initially.
but then a/s came out with the WICKEDLY BRIGHT led lights of the classic line only...
so i just replaced the older incandescent bulb units...
these suckers are blindingly bright (see posts 11-24 below)...
http://www.airforums.com/forums/f37/...tml#post172422
and your CLASSIC unit comes stock with them now.
i also added the dot/3m red/white reflective take used by real truckers, to the back...
and some hippy DAYTIME reflectors, and other eye catchers to the back.
next up is to replace the REAR storage hatch with a LED screen so i can post messages to 'followers'...
like "back OFF sucka"
________
one SIMPLE way to add a higher light would be to use the led truck strips right UNDER the window/above the beltline trim....
http://www.pickupspecialties.com/LED..._light_bar.htm
i've done this on the truck but opted NOT to on the trayla...
for now.
a MORE useful upgrade to lighting is some MEGA BRIGHT back up lights for nite time parking in the treez...
http://www.airforums.com/forums/f206...ons-17807.html
and misc safety stuff...
http://www.airforums.com/forums/f48/...des-37028.html
cheers
2air'
