Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 07-24-2008, 08:42 PM   #1
ronstory's Avatar
Profile:  1975 23' Safari
Portland , Oregon
Cheap LED Tailight conversion at Harbor Freight?
All--
When I was at Harbor Freight getting more picks to remove that darn silicone... I was in the trailer section and saw this:
Harbor Freight Tools - Quality Tools at the Lowest Prices
It is a 12 LED 2" receiver hitch brack light that plugs into the simple 4 pin in-line tailer light connector. The are $6.99 on line at Harbor Freight websiite and would have with a nice long pigtail one you lopped off the 4 pin connector.
The size of the LED is 3.25" square... so with a few mods it should fit in the Monarch taillight on my '75 Safari.
Anybody done this? I'm still at the scraping Silicone stage of my restoration.
Ron
ronstory is offline   Reply With Quote
Old 07-24-2008, 09:30 PM   #2
2airishuman's Avatar
Profile:
Originally Posted by ronstory View Post
...It is a 12 LED 2" receiver hitch brack light that plugs into the simple 4 pin in-line tailer light connector. The are $6.99...
hi ron...
i've got ONE of those.
they are available at wallyworld, and most auto parts stores at similar prices...
i used in on the truck as a receiver light when not towing, for awhile.
it worked just fine, but was eventually replaced with 48 inch led light bar.
the bar is mounted below the tailgate and include directional signals with the brake light function.
it is not NEARLY as bright as the leds now used for tail lights on cars or 'streams...
sure it could be adapted for the trailer,
but for that much effort, look for something a little brighter and better made.
actually these truck light strips could be used on streams too. here is just one quick example....
http://www.pickupspecialties.com/LED..._light_bar.htm
and in ACTION...
http://www.streetglow.com/products/i...ilgate_1-.gif#
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 07-24-2008, 11:35 PM   #3
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
I have a good lead on Silicone remover - if you have lots of it to get rid of.
Uwe
www.area63productions.com
Old 07-25-2008, 01:33 AM   #4
ronstory's Avatar
Portland , Oregon
Yes! I have to remove about 3 or 4 tubes worth. I just bought 10 bottles of "Lift off" Silicon / Latex caulk remover which actually works pretty well... if you use it with Goof-off.
The combo seem to remove the caulk, silicone, vulkem... and nitrile gloves are good for about 30 mins.
Ron
Old 07-25-2008, 06:41 AM   #5
Profile:  1973 27' Overlander
Loganville , Georgia
I found a thread in these forums which recommended D/Solve it. You can buy it at Ace Hardware. The stuff works really well removing silicone, Vulkem etc.
I replaced all my lights with peterson lights. I bought them at Northern Tool. I thought I got a great deal and they look like the original ones that were on my airstream.
SIU Bound
Brian
Lothlorian is offline   Reply With Quote
early 70s tailight LED conversion Lumatic Lights - Interior & Exterior 2 06-22-2008 08:06 PM
71 tailight LED replacement Lumatic Lights - Interior & Exterior 1 05-03-2008 10:30 AM
Harbor Freight has a sale on 45W solar array bobechs Generators & Solar Power 10 07-11-2005 09:20 PM
Harbor Freight = Hubby's Heaven ! Herm and Debby 1970-79 Tradewind 2 12-20-2004 07:04 PM
Harbor Freight Buying Tip... malconium The Vendor's Forum 19 09-09-2004 06:22 AM
