Old 12-11-2015, 10:14 AM   #1
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
Changing fuse amp size
Question has anyone changed the fuse amp size after converting from incandescent bulbs to led ?
I have changed all the interior and exterior bulbs except tail lights and those will be next.
Since the amp draw is significantly lower has anyone changed the fuse size?
thehandyman is offline   Reply With Quote
Old 12-11-2015, 10:18 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Fusses are sized to protect the wiring. Do not lower the value.
MICHAEL
Old 12-11-2015, 10:50 AM   #3
batman's Avatar
1964 22' Safari
modesto , California
Exactly what Michael (AWCHIEF) said.
Fuses are rated to protect the the gauge, type and length of wire used.
Not to protect the components being used, e.g., bulbs, fans, pumps, etc.
Even though the amp draw in the new light replacement is lower than the original, it is not necessary to change the fuse value to a lower rated fuse.
-Dennis
batman is offline   Reply With Quote
Goucho couch,original am/fm 8 track & lots of wood & aluminum from interior remodel gquailhunter Airstream Classifieds 0 09-19-2015 04:25 PM
Changing Tire Size (225 to 235) funkill Tires 1 04-02-2013 09:40 AM
changing hitch size bwaysteve Hitches, Couplers & Balls 3 11-24-2009 10:43 PM
Changing out faucets- what size copper piping? charlie tuna Fresh Water Systems 10 08-22-2006 11:02 AM
