If you do not have a tester to check the Airstream wiring I think you can assume the purple wire is the hot wire. As for the fixture black is commonly used for the hot wire.
Now that said the LED lights are polarity sensitive. Touch the wires as described above, positive to positive, and see if the light works. If not reverse the fixture wires and test again.
2004 Excursion 4x4
