Old 10-14-2016, 08:54 AM   #1
1972 Argosy 22
Shalimar , Florida
Ceiling light replacement
Wife wants certain light fixtures to replace the original ceiling lights front and rear. All I can find is 120v light fixtures. Can I put a 12volt LED bulb in this fixture and if so, how do I wire it up? The front light has a wall switch and one wire sticking down from the ceiling, the rear light was switched at the light with two wires sticking down from the ceiling, one hot and a ground. Thanks for the help. (1972 Argosy 22)
Andersojd is offline   Reply With Quote
Old 10-14-2016, 10:50 AM   #2
batman's Avatar
1964 22' Safari
modesto , California
Hello Andersojd (1972 Argosy 22),
The wiring will not be your problem.
120v typically has 3 wires Black (120v hot), white (neutral), and green (ground).
On your trailer Black should be (12v hot), white should be (ground).
Meter yours to make sure.
On a 120v fixture conversion, the black will become the (12v hot), the white will become the (ground), the green will become a spare as it is not needed on a 12v system
That being said, your issue is, now you have to get 12v lights for the fixture, or change the sockets to accommodate a 12v light or LED. Doable, but not so easy. It may require rewiring the entire fixture.
In my opinion it would be easier to search for actual 12v light fixture options on line. Like a marine supply store or something like rvupgrades.com, etc, etc.
Maybe not so easy to convince the wife, lol.
I hope this helps. Best of luck.
-Dennis
batman is offline   Reply With Quote
Replacement interior ceiling light switch richw46 Lights - Interior & Exterior 1 02-04-2015 08:46 AM
Replacement for original 1970s round ceiling light fixture ViewRVs Lights - Interior & Exterior 9 10-28-2013 12:53 PM
Plastic light switch for ceiling light in 1979 Sov. Bowmans Lights - Interior & Exterior 4 10-14-2009 06:17 PM
Ceiling light lens Replacement niftypkg Lights - Interior & Exterior 1 05-31-2009 12:43 PM
