Old 11-10-2011, 01:14 PM   #1
1999 34' Excella
Troy , Texas
Ceiling light ground
Well...here is my question...my ceiling light is fine...it works...it just doesn't work when I install it in my bedroom ceiling...I think that the material that the 4 screws attach too is not allowing it to ground...the backing in which the screws attach are wallowed out...I tried to put in a larger screw...still didn't work...the perimeter of the light receptable is made of a very thin metallic material...just strong enough to hold the light to the ceiling...can this be replaced?? I can slap the face of the light and it will come on then off...this particular light was one that was working fine in the front of the trailer...so I switched the front with the bedroom light...it seems that I do not have a good ground...any help would be appreciated..
excella99 is offline   Reply With Quote
Old 11-10-2011, 02:52 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
The easiest thing to do is run a ground wire to bond the light to the frame or aluminum skin.
Old 11-10-2011, 02:58 PM   #3
1999 34' Excella
Troy , Texas
excella99
Thanks Jammer...I will try it out...
Old 11-11-2011, 02:18 PM   #4
1999 34' Excella
Troy , Texas
Jammer....I ran a wire to frame...light still does not work...one bulb came on for about 2 seconds then went off....totally dumbfounded by this...the light worked in the front of the trailer...the light I took out of the bedroom didn't work there..but it works in the front of the trailer???? I am getting power to the light ...or it wouldn't flicker??? I think I will replace the switch on the wall and see if that does it
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 5 05-12-2014 05:05 AM
Interior ceiling light swap out help DougZ Lights - Interior & Exterior 16 06-03-2011 09:55 PM
Stereo With Overhead light?? Eliminator46 Audio, Video & TV 10 05-20-2011 02:12 PM
first ceiling light Segue Lights - Interior & Exterior 2 05-14-2011 01:18 PM
