Old 09-09-2014, 09:05 AM   #1
Georgia1984's Avatar
2014 Interstate Ext. Coach
Jefferson , Georgia
Ceiling LED lights won't turn off
We are newbies.. so please have mercy on us.
My husband and I have a 2014 interstate and yesterday while driving from Florida we realized the ceiling lights will not dim or turn off with the switches.
We actually had to cut the power off to the van so our baby could sleep in the back.
Right now we are driving and ceiling lights are on and really bright.. switch is in off position.. we are puzzled ;(
Any thoughts??
Georgia1984 is offline   Reply With Quote
Old 09-09-2014, 10:15 AM   #2
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . wrong switch ?, dash lights all the way up, which activates overhead lights in a Ford. .. I'm trying here ( I know, very trying ) Good luck, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 09-10-2014, 06:50 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Don't have an Interstate, but was wondering if there is more than one switch that controls the same lights? If so, do both have to be "off"... Like Craig, just tryin' to help ...
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 09-11-2014, 04:59 AM   #4
Jefferson , Georgia
Yes we have read all the manuals .. looked everywhere...
no other switch.
Old 09-11-2014, 05:38 AM   #5
Retired.
. , At Large
no other switch.
Check the switch to the sliding door. If it isn't functioning correctly, the lights won't go off. Also, you may have a "door ajar" waring on the dash, but not always. One of our customers had this issue, and I pulled a fuse from the panel under the driver's seat to temporarily shut them off.
Old 09-11-2014, 07:34 AM   #6
no other switch.
Call Airstream.
937-5966111
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-16-2021, 10:58 AM   #7
Hershey , Pennsylvania
Any thoughts??
Did you guys ever figure it out? I have a 2014 and is doing the same thing.
OldRudds is offline   Reply With Quote
Old 05-20-2021, 01:39 PM   #8
Bellingham , WA
check this out = https://www.airforums.com/forums/f44...ml#post2496150
romanf17 is offline   Reply With Quote
Old 05-20-2021, 03:02 PM   #9
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
Weird! I just answered one like this for someone else today:
The toggle on your wall switch probably separated from the terminal. Pull the switch off and take a look
- Stewart
s1000pre is offline   Reply With Quote
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
won't turn off! AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-22-2009 09:52 AM
Fridge Fan won't turn OFF clancy_boy Refrigerators 7 09-04-2007 08:55 PM
