Old 07-13-2008, 11:46 AM   #1
TDOW's Avatar
1966 22' Safari
Madison , Wisconsin
Caravel cone light
Greetings from WI!
Need help trouble shooting a '67 cone light. I'm trying to insert the ball mechanism into the tube. This enables the light to swivel/twist in the direction needed to read at night. Any ideas? Thanks for your time!
TDOW is offline   Reply With Quote
Old 07-13-2008, 06:23 PM   #2
Alumanutz's Avatar
1966 22' Safari
Chico , California
I took my lights compleatly apart,repainted them and reassembled. The ball on mine would not stay in the socket. I ended up placing the ball in the socket and compress it with my vise. I them used vice grips to close up the end of the socket and keep the ball in. I hope this makes sense. I have one more to do so I will try taking some photos and post them if you need.
Alumanutz is offline   Reply With Quote
Old 07-13-2008, 08:54 PM   #3
Darol Ingalls's Avatar
TDOW, The "ball" is soft cast metal and wears down rapidly. The tube is soft aluminum and stretches easily. Basically a very poor design to start with. Alumanutz' solution is about as good as you can do short of finding a position for the light you like and epoxying it in permanently. Getting the wire back inside and replacing the socket is another joy with these lights. Darol
Darol Ingalls is offline   Reply With Quote
Old 07-15-2008, 04:53 PM   #4
TDOW's Avatar
1966 22' Safari
Madison , Wisconsin
cone light
Thanks you guys for your response. I'll give the "squeeze" method a try! Last time we used it, the light dropped down, hanging by its wires and even threw sparks! With all our humidity, I don't really need an electrical perm. Ha!
caravel
vintage cone-shaped interior lights Rog0525 Lights - Interior & Exterior 2 04-19-2007 07:57 PM
Scare light and marker light won't work??? shinybean Lights - Interior & Exterior 12 02-12-2007 08:51 PM
'69 Ambassador Interior - soon to be Snow Cone Stand radiodial General Interior Topics 0 11-10-2006 10:07 AM
'69 Caravel, light switch Julison 1969-1971 Caravel 9 10-10-2005 04:18 PM
light globe/light covers David Hall Electrical - Systems, Generators, Batteries & Solar 5 02-18-2004 06:35 AM
