Old 09-09-2013, 07:03 PM   #1
Airstream Fanatic
ND10CentCan's Avatar
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Bismarck , North Dakota
Can this be done?
With our 1959 Pacer, we kept the original 120 volt overhead light. It is a great looking fixture we think but want to be able to use it also on the 12 volt system if we boondock. Is this possible? What is involved in doing it if it can be done?
Sandy
ND10CentCan is offline   Reply With Quote
Old 09-09-2013, 07:08 PM   #2
1981 31' Excella II
New Market , Alabama
I am sure it can be done. Do you have a photo of the light?
Perry
Old 09-09-2013, 07:15 PM   #3
Southwestern , Ohio
In our 1960 Pacer all the interior lights (three) were 120 V except for the light fixture in the middle of the ceiling, which had sockets for both 120 V and 12 V bulbs. (That was the only 12 V device in the trailer; the '60 Pacer did not originally have a coach battery, just a connection to the tow vehicle battery.)
One option is to put in a small inverter to give you enough 120 V to run the lights from the 12 V battery. We did that and it worked pretty well with compact fluorescent bulbs in the 120 V sockets. (We also added a coach battery.)
Alternatively, you could run a 12 V wire to the fixture and put one or two LED lamps inside the fixture to provide 12 V lighting when boondocking.
Nuvite-F is offline   Reply With Quote
Old 09-09-2013, 07:54 PM   #4
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
I just got a 59 pacer. I haven't checked it out, but I'm pretty sure the setup is just like Nuvite-F described for his 60. So you should have a 12v line running to the overhead light already.
Kevin
kevinb is offline   Reply With Quote
Old 09-09-2013, 08:35 PM   #5
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
We will check that out...thanks.
Thanks for that info. We learn something new every time we turn around. Keeps us on our feet.
Sandy
Old 09-09-2013, 08:43 PM   #6
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Something to check out
[QUOTE=kevinb;1352223]I just got a 59 pacer. I haven't checked it out, but I'm pretty sure the setup is just like Nuvite-F described for his 60. So you should have a 12v line running to the overhead light already.
Kevin[/QUOTE
DH will be checking that out in the next few days. Every day is a new day with Airstreams. It will be interesting to see what he finds. He is going to look it over and hopefully we can boondock with this little trailer.
Thanks for the reply.
Sandy
