Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 12-01-2002, 08:35 PM   #1
Zed2
Zed2's Avatar
Profile:  1986 25' Sovereign
1965 17' Caravel
Plano , Texas
Bulbs - Tail and Clearance
Can anyone give me the bulb numbers (type) for the tail lights and clearance lights for a 1965 Caravel.
I removed both of tail lenses and noted that the bulbs were dual filament types but only had two leads to each scocket. The brightness of the bulbs is very low since only one filiment is lit, which leads me to believe that I do not have the correct bulbs.
Regarding the clearance lights, I want to verify that I have the correct bulbs in place.
Thanks in advance for your help.
Keith
Zed2 is offline   Reply With Quote
Old 12-02-2002, 09:37 AM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
The tail light bulb number back then was 1034. It basically has been replaced with 1157. One of the filaments is for tail lights (dim), and the other filament is for the turn signal and brake light (bright).
The clearance lights, if they are the original, used a number 57 bulb.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 12-02-2002, 11:24 AM   #3
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
Simple electricity
The bulb has only two contacts respective to the filaments.
The ground comes from contact to the chasis of the light housing and in turn to the skin of the trailer.
Lights will glow dim because of poor ground or bond to the trailer.
I have been to this school and let me tell you that a poor ground will truly stump the best of electrical engineers.
Smily
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 07-13-2005, 12:53 PM   #4
Dwight
Dwight's Avatar
Profile:  1999 34' Excella
Joshua , Texas
LED Tail Lights
Has anyone converted their lights to LED units?
Dwight is offline   Reply With Quote
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 19 12-12-2003 08:39 AM
