Old 07-28-2014, 07:11 AM   #1
Naper's Avatar
Loretto , Ontario
Bulb Replacement Help
Lamp stopped working so I guess its the bulb. How does this thing come apart?
Naper is offline   Reply With Quote
Old 07-28-2014, 07:14 AM   #2
SteveH's Avatar
Common Sense , Texas
Yes, if it's like mine, the front lens sort of twists off, and then there's a halogen bulb in there that unplugs.
Regards,
Steve
Old 07-28-2014, 07:23 AM   #3
Naper's Avatar
Loretto , Ontario
I have twisted, turned, pulled, poked, no way this thing is coming apart. Whats the trick?
Old 07-28-2014, 07:47 AM   #4
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
Does not twist off.
There will be a tiny gap between where the clear plastic lens meets the bronze metal. Use a small flat blade screwdriver to work between the lens and metal to pry the lens straight out and off. The bulb has two pins and will pull straight out.
I recently replaced my halogen bulbs with LEDs from M4 LEDS (google them). Same amount of light as halogen, but a lot cooler and use much less amps if you ever boondock.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 07-28-2014, 08:01 AM   #5
SteveH's Avatar
Correction, I was wrong, they do not twist off. (must have been a previous trailer I was thinking about) Went and looked at mine, and they are just like yours, and Fred is right, the lens and the metal ring around it will come out with something like a knife prying on it.
Regards,
Steve
Old 07-28-2014, 08:20 AM   #6
dznf0g's Avatar
Oswego , Illinois
They are TIGHT. be careful you don't damage the plastic.
-Rich-
Old 07-28-2014, 08:38 AM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I've found that dental picks are good for this; if you can get the tip of the pick in, a twist puts the tip of the pick behind the lens for easier pulling and less prying. My toolkit now has several dental picks in different shapes just for stuff like that.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-28-2014, 03:13 PM   #8
Naper's Avatar
Loretto , Ontario
Got it !! Thanks for the help
If any one is interested the bulb is a G4 bi-pin halogen 12 volt 10 watt Sylvania # OSR64415
'Porch' Light Replacement Fixture with 1141 Bulb AirConditioner Electrical - Systems, Generators, Batteries & Solar 4 09-10-2015 11:56 PM
turn signal light bulb replacement...bulb not turning ArgosyMinuet All Argosy Trailers 2 04-28-2013 09:52 AM
Ceiling bulb replacement? TennisMan 2007 Safari SE 2 09-04-2007 08:17 AM
Replacement Bulb for Remote Spotlight? swebster Classic Motorhomes 3 06-17-2005 01:06 PM
