Old 04-20-2009, 08:31 AM   #1
Weekend Warrior
Mr.Sovereign's Avatar
2000 34' Excella
1987 29' Sovereign
Pace , Florida
Images: 32
Brighter taillights without converting to LED
There has been a lot of discussion around taillight converstion to LED. LED's are brighter, more reliable, use a lot less energy and look really cool. The only real downside is the cost of conversion. Of course, the newer Airstreams have a direct replacement option at about $25 per taillight. Past that, older AS units have to "create" some sort of retrofit, and there are some fantastic examples of what people have done. Still, cost of retrofit is going to be somewhere in the $20+ range per taillight.
I actually "stole" an old hot-rodder trick. Many of the 30's and 40's hot-rod conversions fight the same problems we do with not having a bright enough taillight. Most of them are using taillights that are very small (approx 2" x 5"). What most all of them do is this:
(1) Paint the inside of the can gloss white, and
(2) Replace the 1157 dual filament bulb with a 2357LL dual filament bulb.
Here's why:
(1) Contrary to popular belief, a good clean white is a better reflector than a silver paint. A mirrored finished is perfect if all the angles are designed to reflect the light backwards. Today's reflectors are parabolic and direct a lot of light energy to the right place. The cans that we have in our older units are not shaped to do so. Painting them gloss white will make a tremendous difference (especially from the glavanized coating that they currently are). Be sure to use a high grade paint (industrial is best) that can withstand the heat associated with the bulb. White reflects all wavelengths, so you'll get a nice bright, even light from the taillight.
(2) The long time standard 1157 bulb seems to leave something to be desired. A good replacement is the 2357LL (NOT the std 2357). Not only does the 2357LL extend the life, but it is a higher candlepower (cp) bulb. See the comparison
1157 taillight power = 3
brakelight power = 32
2357 taillight power = 3
2357LL taillight power = 3
brakelight power = 40
You get 25% more light for a simple bulb swap. Power consumption only increases from 26.9W to 28.9W, so not a major increase in current requirements. Wiring size will not be a factor in this improvement.
The picture doesn't do it justice. I was amazed when I did the "conversion". I'm still using the original lens, which I plan to replace in the near future.
Hopefully this will help some who don't want to spend the money to upgrade to LED!
Happy Monday,
Warren
ID:	78864   Click image for larger version
________________________
W. Warren Whitfield
Pace, Florida (near Pensacola)
2000 Excella 34'
2003 Suburban 1500 tow vehicle
Mr.Sovereign is offline   Reply With Quote
Old 04-20-2009, 08:36 AM   #2
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
I'll give it a try on my 86.
Nice diamondplate with cleats!
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 04-25-2009, 10:57 PM   #3
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Did you do a voltage reading? That's the other half of the equation (the important one, IMO).
Nicely done write-up and photos, thanks.
slowmover is online now   Reply With Quote
Old 04-26-2009, 12:24 AM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Good idea.
Hi, I like the white idea. In the 70's I painted the reflectors silver and cleaned the lenses really good on some cars and it made a big difference. Also I either cleaned the bulbs or replaced them.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-27-2009, 05:37 AM   #5
Weekend Warrior
2000 34' Excella
1987 29' Sovereign
Pace , Florida
Images: 32
No, I did not take a voltage reading (before or after). However, I would not expect it to change very much. The amperage only went up slightly....not enough to where I would expect it to create voltage decay.
I should have taken a "before" picture for comparison. I saw a pretty significant improvement with the changes, though.
Thanks for the questions.
Happy Monday,
Warren
W. Warren Whitfield
2000 Excella 34'
Old 09-26-2009, 10:03 PM   #6
1972 27' Overlander
Saline , Michigan
Great suggestion Warren,
I just finished cleaning my lenses, painting the cans white, and did the bulb swap.
Big difference.
Steve
loechli is offline   Reply With Quote
Old 09-27-2009, 05:29 AM   #7
ryan3326's Avatar
1976 31' Sovereign
Columbus , Indiana
thanks for the tip - I just replaced all of my lenses and will give it a try.
In Search of "Hill Country"
www.doublesanddogs.com
ryan3326 is offline   Reply With Quote
Old 09-27-2009, 08:18 AM   #8
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
How about single contact bulbs?
Warren....great idea! Do you happen to know of a similar bulb replacement for single contact bulbs? I want more put out for my side marker lites. I did paint the base plates white as suggested.
Old 09-27-2009, 08:33 AM   #9
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I did it on my 71. It works. Why on earth did they paint the cans black anyway?
Don't forget to mask off the fiber optics in the tail/brake/stop light.
Old 09-30-2009, 09:45 PM   #10
Dan@LED4RV's Avatar
Denton , North Carolina
one point of failure
Warren
Warren,
Good job on the painting. I think there is a product has come down in $ and has a lot of pop.
And they are in that $ range
Click here to see their video.
And they have it in a kit for all 6 lights
Has anyone tried them??? Looks pretty good.
Fixer
Dan@LED4RV is offline   Reply With Quote
Old 10-01-2009, 04:24 AM   #11
down south , South Carolina
MR. SOVEREIGN!!! DON'T BACK INTO THAT BASKETBALL POLE!!!!!!
Dieselgrin is offline   Reply With Quote
Old 10-01-2009, 07:08 AM   #12
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
Thanks! I know now what the next "project" is. Wanting brighter lights back there but not wanting to give up the fiber optic indicators. (that I think are the coolest thing on the trailer) This will fit into my super tight budget and accomplish what I want! Wish I could send KARMA, thanks just is not enough.
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 10-04-2009, 03:06 PM   #13
Weekend Warrior
2000 34' Excella
1987 29' Sovereign
Pace , Florida
Images: 32
I've not had any luck finding brighter replacements for the single contact bulbs. Specifically on the side marker lights (Grote markers with tiny bulb), I'm fairly certain there is not a replacement. I searched all of the catalogs with that base number and they all have the same power ratings. Sorry I couldn't be more help.
Happy Sunday,
Warren
W. Warren Whitfield
2000 Excella 34'
'07 Safari Taillights marta5 Lights - Interior & Exterior 1 03-24-2008 09:48 AM
Glass in, taillights on. Petethefeet Cleaning, Stripping & Polishing 3 03-20-2008 11:52 AM
4" by 4" LED Taillights for Vintage Trailers. startrekker2001 Lights - Interior & Exterior 7 09-05-2007 02:27 PM
LED Taillights scf31 Lights - Interior & Exterior 7 04-25-2005 07:47 AM
