Old 04-11-2010, 06:26 AM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
breakaway switch
Looking for wiring diagram on how to wire a breakaway switch........thanks
toastie is offline   Reply With Quote
Old 04-11-2010, 06:30 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Honestly, you really don't need one. Just wire one of the wires on the breakaway switch to the 12 volt battery lead, and the other one to the electric brake wire, both on the tongue.
Old 04-11-2010, 06:53 AM   #3
toastie's Avatar
1955 22' Safari
Will I need a thermal fuse on the black 12v wire, and what size.......thanks
Old 04-11-2010, 09:38 AM   #4
1980 31' Excella II
Drummond Island , Michigan
No fuse needed. The switch only has a load running through it when it is closed. (The pin is pulled) and that would only happen if the trailer broke away or you were testing the breakaway switch or brakes by manually pulling the pin. I would much rather burn some wiring than have the brakes release on a runaway trailer if the fuse blew for some reason.
Ahzmyrah is offline   Reply With Quote
Old 04-11-2010, 10:06 AM   #5
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
The newer trailers have a 50A self reseting Breaker. Both batteries are tied together then onto the hot buss. The break-a-way has a self reseting fuse as well. 20 or 30A I believe. If the wire is 12GA it will be a 30A. You can get these from a Marine store.
Michelle TAC MT-0
Sarah, Snowball
Breakaway switch. FreshAir Brakes & Brake Controllers 44 02-12-2007 11:18 AM
Breakaway switch replacement LI Pets Brakes & Brake Controllers 6 12-03-2006 08:09 PM
Breakaway Switch PunkZTT Brakes & Brake Controllers 24 05-02-2006 11:48 PM
breakaway switch aeriqua Brakes & Brake Controllers 2 01-09-2006 06:48 AM
Breakaway switch bhsl8 Brakes & Brake Controllers 26 10-06-2003 03:09 PM
