Old 11-29-2013, 09:57 PM   #1
ewbradshaw's Avatar
2008 27' International FB
Sioux Falls , South Dakota
Brake lights on
My right break/rear light came on while plugged in to shore power and not attached to tow vehicle. Any ideas on how to turn it off?
ewbradshaw is offline   Reply With Quote
Old 11-30-2013, 01:21 PM   #2
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
This is an interesting bug and without further info I can only speculate. The exterior lights get their power from the tow vehicle. In the 7-pin plug are the following wires:
Ground
+12V charge line
Brakes (not lights)
Tail lights (includes marker and license plate lights)
Backup lights
Left turn/brake light
Right turn/brake light
For a single brake light to come on while not connected to the tow vehicle, that line must be crossed with a 12V source. I would say to start by looking at the umbilical plug and cable expecting to find a short between that turn signal line and the charge line. But you say this only happens when the shore power is turned on...
Do you not have house battery power available inside the trailer when the shore power is unplugged? Is the battery installed and the Store/Use switch in the Use position? The charge line is normally hot all the time if the battery is connected regardless of the shore power; with it in place and using a 12V test light or volt meter you should find 12V on only one pin of the disconnected umbilical plug. Do your turn signal lights work correctly when the umbilical is plugged into your tow vehicle? With a short from 12V to that turn signal line, that side brake light would be on all the time and not flash with the turn signal or 4-way flasher turned on.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 11-30-2013, 02:32 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Might you have a shirt in the 7 way???
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
DirecLink Brake controller... Mexray Brakes & Brake Controllers 123 01-03-2016 08:58 AM
Brake lights, brake controller not functioning adwriter73 Brakes & Brake Controllers 17 01-16-2014 09:37 AM
2002 LY 26' - Airstream MH Brake Failure Intruder Land Yacht/Legacy Motorhomes 15 08-11-2012 06:59 AM
Street side brake light not working w/ running lights on NicheVintage Lights - Interior & Exterior 7 08-23-2011 05:54 AM
Confusing turn and brake light problem mikeandnora Lights - Interior & Exterior 13 05-29-2011 07:30 AM
