Old 05-17-2009, 08:04 PM   #1
2006 16' International CCD
Castle Rock , Colorado
Brake light / Turn signal issue
Hi -
We happily took our 2006 Bambi out camping for the first time since we purchased it, and half way to the campground the right rear brake light and turn signal quit working. The tow vehicle lights all work. Any ideas? This is not the first time we have towed it. We towed it for 4 days just to get it home with no problems....
Thanks - you guys are always a big help!
Vicki
Miss Vicki is offline   Reply With Quote
Old 05-17-2009, 08:11 PM   #2
richinny's Avatar
2011 34' Classic
if the parking light still works i's say bad bulb or bad connection. first place to check is the connection from the tow veh and the trailer.
Ricky
Old 05-17-2009, 08:28 PM   #3
Mexray's Avatar
1978 28' Ambassador
Morada , California
I agree, check the bulb in the RH stop light unit on your trailer...
also, check the connections of the trailer plugs in both the TV and the Trailer...maybe spray a bit of WD40 like stuff in both plugs, then insert and remove them a couple of times to make sure the connections are making contact...
Ray & Pat; Morada, CA
Old 05-17-2009, 08:41 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
If your tow vehicle has factory tow package wiring, there is a separate 10 amp circuit for left and right trailer lights. If it is not the bulb, it could be this fuse.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 05-28-2009, 05:51 PM   #5
Thanks! It was a fuse just like you suggested. I knew this was the place to go!
Turn signal lens 76sovereign Lights - Interior & Exterior 15 01-29-2009 12:46 PM
'65 Globetrotter led brake/stop/turn tail light kennyp315 Lights - Interior & Exterior 3 12-06-2008 08:10 AM
Brake and Turn Signal Problems with Mercedes Atlasonorder Lights - Interior & Exterior 12 11-09-2008 03:29 PM
turn signal problem Cruiser Electrical - Systems, Generators, Batteries & Solar 9 10-25-2004 07:27 PM
Brake/Turn Light Wiring Question (late 70's) DPeakMD Electrical - Systems, Generators, Batteries & Solar 3 07-14-2004 01:46 PM
