Old 05-07-2009, 01:01 PM   #1
AireHeads
AireHeads's Avatar
1965 20' Globetrotter
St. Petersburg , Florida
brake light housing 1965 GT
I've searched but have not found any replacement sources or info about the plastic housing for the brake lights on our 1965 globetrotter. Any suggestions or advice would be appreciated.
Michael
AireHeads is offline   Reply With Quote
Old 05-07-2009, 08:27 PM   #2
1965 24' Tradewind
Warner , New Hampshire
Michael,
I know what your talking about. I have the same tail light issue as you. I just went to a local metal shop today to see if they could make some new one's out of aluminum and they said it could end up being around $300.00 each. There is a local body shop that is known for custom work that could make a copy of my plastic tail light assembly out of fiberglass. If you need some templates I could have this done for you. So it looks like i'm going to have to repair mine with fiberglass and live with it.
Brian
briheath is offline   Reply With Quote
Old 05-07-2009, 10:29 PM   #3
AireHeads
AireHeads's Avatar
Brian,
Thanks for the offer of the templates, but not necessary. I was hoping for some solution without reinventing the wheel. I've considered making a mold and building a new set out of fiberglass. But for right now I'm happy to have the lights working and will be working on more pressing needs.
michael
Tail light housing on '65 Overlander 65 overlander Lights - Interior & Exterior 5 01-20-2013 05:28 PM
1965 plastic tail light assembly briheath Lights - Interior & Exterior 4 09-14-2009 11:18 PM
'73 Overlander turn signal light housing Lothlorian Lights - Interior & Exterior 4 05-28-2008 06:35 PM
I need a reverse light housing!!! gretchen Lights - Interior & Exterior 1 05-21-2007 08:08 PM
Brake warning light tandemfish Mechanics Corner - Engines, Transmission & More... 3 04-25-2006 07:04 PM
