Old 04-14-2014, 06:44 PM   #1
1964 22' Safari
Mason , Michigan
Best wire connector for 12 gauge stranded wire
Hi,
I am about to rewire my 1964 Safari. I am using 12/2 gauge stranded marine wire for the 12 volt and 12/3 stranded marine wire for the 120 volt.
Some say you should not use wire nuts to make the connections. Closed end crimped wire connectors should be used.
Not sure what to do, and what size closed end connectors would I need.
joe
jcarnevale is offline   Reply With Quote
Old 04-14-2014, 07:18 PM   #2
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Joe, in our 2010 Airstream I have found nylon crimp caps used by the factory.
14-10 Gauge Crimp Connectors 100 Pieces - WiringProducts
The NSA -- The only part of the government that listens.
newroswell is offline   Reply With Quote
Old 04-14-2014, 07:32 PM   #3
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
I don't use wire nuts.
For 12V I use 3M crimp butt connectors with heat shrink.
I prefer to use these terminal blocks for AC wiring with stranded wire.
I would suggest you consult with Lewster for his advice.
Lance
Top is offline   Reply With Quote
Old 04-14-2014, 08:17 PM   #4
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I generally prefer to solder connections and insulate with shrink tube.
If you want to use crimp type connectors, I believe there are some with a gel inside that reduces chances of corrosion, especially if used in exposed areas such as feed wires for electric brakes. Never tried them but that is what I would look for.
In trouble-shooting things that were not working on trailers, I have often found the problem to be old crimp connectors and wire nuts that were full of corrosion and as a result were open circuit - the connections pretty much just fell apart when touched.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 04-14-2014, 08:46 PM   #5
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
The heat shrink, self sealing butt connectors are an excellent choice. We have been using these professionaly for almost 30 years. When fitted correctly the failure rate is zero.
For DIY use you don't need the special die-set crimpers, just a standard stripper/crimper will do. Don't over crimp, or pierce the outer tubing. Apply heat and that splice will never come apart.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 04-14-2014, 09:13 PM   #6
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
A good glob of Liquid Electric Tape won't hurt, either.
Cannonball is offline   Reply With Quote
Old 04-14-2014, 09:18 PM   #7
Southwestern , Ohio
I like to use metal crimp connections insulated after crimping with shrink sleeving or electrical tape.
But to tell you the truth, both of our Airstreams (1960 and 1980 models) have been full of wire nut connections from the factory (and/or previous owners) and I have never seen one fail.
Nuvite-F is offline   Reply With Quote
Wire color code for brake connector DL46 Brakes & Brake Controllers 4 06-22-2013 07:26 AM
Convert Hard Wire to Bulkhead Connector?? 10Smiles Electrical - Systems, Generators, Batteries & Solar 8 07-24-2011 10:23 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 08:09 PM
What size breaker for 8 gauge wire? guy99 Electrical - Systems, Generators, Batteries & Solar 7 11-20-2005 01:24 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 12:09 PM
