Old 05-24-2010, 06:22 AM   #1
1969 21' Globetrotter
Cambridge , Massachusetts
Best LED tail light option for '69-'74
Can any one help me track down the best LED tail light retrofit product/method compatable with the bezel/housing for Airstreams in the 1969 to 1974 age range? Are there any of the many LED lighting threads that are specific to this situation? Will I be replacing just the light cluster or the lens as well?
John
JoePfznik is offline   Reply With Quote
Old 05-24-2010, 06:30 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Did you know if you repaint the inside of the can white and switch to a brighter bulb you can get a brighter tail light and still have the fiber optic indicator working?
Old 05-24-2010, 07:52 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Tail lights are DOT approved as a system, bulb and lens. There are countless listings for replacement bulbs for the numbered bulb used in tail lights but that does not mean they are acceptable for that usage. The design of the fixture takes into consideration the placement of the filament with respect to the reflector to focus light on the lens thus creating the brightest possible light directed to the rear. Think of a lighthouse and the effect obtained there from such a small light source.
Look at this thread post 49, 51, and 54 for what I did to get the LED results and remain legal.
http://www.airforums.com/forums/f311...s-23544-4.html
2004 Excursion 4x4
Old 05-24-2010, 08:02 AM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
It works, it's brighter, and I have used this for several years with no problems. To me that's more important than what the DOT says. I'm not sure I remember the bulb sizes but I think the original bulb is a 1157 I am only aware of one bighter bulb with the same base, I think a 2057.
No doubt LEDs are even better, but with a light bulb and a little white paint you are done.
Old 05-24-2010, 08:21 AM   #5
HowieE's Avatar
Images: 12
His question and my post are directed at the usage of LEDs in conjunction with older lights. Yes you can increase the brightness of the existing fixture by increasing the reflectivity of the fixture but that was not the question.
2004 Excursion 4x4
Old 05-24-2010, 08:25 AM   #6
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I did them here #276
http://www.airforums.com/forums/f416...-26902-20.html
Old 05-24-2010, 08:37 AM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Do it Kips' way....or my "Presidential Solution".....
Quick and easy...
LED Pads : LEDs 4, Recreational Vehicles
Old 05-24-2010, 08:42 AM   #8
HowieE's Avatar
Images: 12
Originally Posted by Melody Ranch View Post
That is exactly what I am saying will not meet DOT requirements. If you live in a state where insurance companies are looking for a way out or lawyers are not looking for work that may work.
2004 Excursion 4x4
Old 05-24-2010, 09:10 AM   #9
reggiemon's Avatar
1959 18' "Footer"
Corpus Christi , Texas
Here is a link to the company I used. They say which ones are DOT approved. I do not know if there is a size that will work for your requirements.
http://www.closertowholesale.com/
My link on my conversion but I know that it does not apply to your trailer.
http://www.airforums.com/forums/f447...emy-52497.html
Good luck on finding something!
1959 "Globester"
reggiemon is offline   Reply With Quote
LED tail light conversion Pahaska Electrical - Systems, Generators, Batteries & Solar 138 02-24-2018 06:03 PM
1966 Safari LED Tail Light Upgrade Pat H Lights - Interior & Exterior 13 03-07-2010 09:28 AM
'65 Globetrotter led brake/stop/turn tail light kennyp315 Lights - Interior & Exterior 3 12-06-2008 07:10 AM
LED Tail Light Problem wdkueser Lights - Interior & Exterior 7 09-16-2006 06:58 PM
4-Inch 10-LED stop turn tail light ($11) COUPON** Wabbiteer Electrical - Systems, Generators, Batteries & Solar 1 07-20-2006 09:27 AM
