Old 05-16-2011, 08:04 PM   #1
Lothlorian's Avatar
Loganville , Georgia
Bending Lexan with heat
We are keeping the original interior light covers for our 1960 airstream. These are the rectangeular ones that go over the twin beds and the bathroom. The original are cracked.
I read where you can bend lexan and form it using a heat gun. Has anybody ever done that? I checked Vintage airstream supply and only found inside light covers for 1965 and 1966.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 05-16-2011, 08:16 PM   #2
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
You can, but you have to be careful.
It can be like glass. Once it gets "plastic" it will bend very easily.
Michelle TAC MT-0
Sarah, Snowball
Old 05-16-2011, 08:21 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Brian,
Try experimenting with some smaller pieces in an oven. I have a friend that does this when he makes windshields for motorcycles with great success. You have to find the right temperature and duration of the heat soak to get the Lexan into it's 'plastic' state so you can bend it. You should have no problem once you try a few pieces.
Old 06-29-2011, 07:19 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You need to be aware that Lexan polycarbonate absorbs water. If you heat it too fast when it is moist you will cause bubbles to be formed in the plastic. Take it slow and heat it at about 200 degrees for a couple hours in the oven before you raise the temperature to close to 350 degrees when it will become pliable. You might check the Scabic website that now owns the former GE Lexan tradename and product.
Duo-Therm Heat Pump/AC myrna Furnaces, Heaters, Fireplaces & Air Conditioning 0 04-12-2011 10:46 AM
Had the honor to step inside a 1962 Bambi this weekend and fell in LOVE with the heat J5MM LP Gas, Piping, Tanks & Regulators 9 03-14-2011 03:52 PM
Ignitor Carbon, Poor Heat linc54 Furnaces, Heaters, Fireplaces & Air Conditioning 5 01-30-2011 07:09 PM
Heat Pumps Brianv512 Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-19-2011 06:15 PM
Need new LP heat source for short bursts of winter use pyrenees Winter Living 12 01-04-2011 09:41 PM
