Old 06-01-2015, 07:23 PM   #1
1961 22' Safari
Collegeville , Pennsylvania
Bathroom Vanity Lighting Suggestion
Pardon this noobie question. I'm working on a 1960 Safari and it's missing a lighting fixture above the rear window below the mirror. There are 12V and 110V wires coming out of the wall and a 110 outlet near by.
Anyone have a lighting suggestion? Should I just wire nut the 110 off and use a 12V fixture or are there 12V / 110V combo options available? It's not a very large space.
TheHandyDan is offline   Reply With Quote
Old 06-01-2015, 07:58 PM   #2
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Assuming you have a 12 volt converter (similar to the antiquated univolt) I would recommend a 12 v fixture. If you have access to 120v then your converter supplies power to the fixture. If you don't have 120v available you run it off the batteries. Thats the best of both worlds. The new led lights are super efficient.
Gregsch is offline   Reply With Quote
Old 06-02-2015, 04:02 AM   #3
1961 22' Safari
No converter at the moment. The other light fixtures have a 12V switch and a 120V switch with two bulbs, respectively. It's such a small space The other fixture styles wouldn't fit but I'm assuming something similar would have gone there.
Bathroom vanity and shower refinish felixville Cabinets, Counter Tops & Furnishings 14 03-26-2015 07:27 AM
Bathroom vanity and Bathroom vent lights... sovereignrwe Electrical - Systems, Generators, Batteries & Solar 10 01-05-2010 06:30 AM
Bulb # for interior bathroom vanity lights wacnstac Lights - Interior & Exterior 3 05-05-2008 04:55 PM
'69 bathroom vanity lights goransons 1959-69 Tradewind 14 08-29-2007 08:22 PM
