Old 02-20-2010, 10:23 AM   #1
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Bathroom and back overhead lights out in '72 TW
So from time to time the light in the bathroom and the last overhead light go off for a while and usually come back on. Thought that there were wires in the back closet that if movement in there causes the connection to go bad but on my last outing they went out and couldn't locate the break in connection in the closet. Haven't checked the fuse yet. Has anybody tracked down this wiring/circuit? Also the front overhead light didn't come on either but the middle one was fine.
RichHog is offline   Reply With Quote
Old 03-02-2010, 06:57 PM   #2
1972 31' Sovereign
Des Moines , Washington
RichHog,
I have been down that same road, I will share the knowledge I have gained from here! All the lighting wire runs are in the center panel. Have you checked the fuses in the univolt? Do you have power to the switches? I'm sure someone else will add to this.
Curt
2wheelin is offline   Reply With Quote
Old 03-03-2010, 08:13 AM   #3
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Light Switches
Well the back lights came on about 12:00 as I was drifting off to sleep so I switched them off. It's intermittent for sure. Could be the contacts on the fuse in the univolt as more than one light is effected.
Old 03-03-2010, 08:32 AM   #4
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
My guess would be a loose wire. My 76 Argosy did the same thing. Randomly, I replaced the fuses and it still happened, moved some wires and magic, it came on and now stays on, or so it did until I sold her.
Shane
http://i52.photobucket.com/albums/g2...h_postcard.jpg
"Stay Thirsty My Friends"
Tow Vehicle" 2011 Superduty Diesel!!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Roll Vinyl vs. Vinyl Tile in Bathroom? Roadrunner Repairing/Replacing Floor &/or Frame 6 09-29-2011 07:23 AM
Can I pull out the bathroom without taking apart the rest of the trailer? icebox500 General Interior Topics 0 07-30-2011 01:26 PM
Air conditioning in the back? Skater 1994 - 1996 Excella 4 07-19-2011 11:55 AM
New Idea for '70s overhead lights - LED / Fantastic erock53 Lights - Interior & Exterior 12 07-15-2011 08:04 PM
Bathroom pictures 1974crane General Repair Forum 0 06-03-2011 04:01 PM
