Bathroom and back overhead lights out
This ones intermittant and tonight it went off, both my bathroom light and the 6 light panel in the back section went out. It seems these two are somehow on the same wiring and I'm not sure where and how it runs and where the break is. Was putting in some LED lights in the back overhead when both these lights went out. Checked all wiring in the 6 panel, pulled twisted uncapped the caps. There is a single black wire that feeds this one. Then went to the univolt panel and removed one at a time the three fuses in it, front section, mid section, and the third bottom one was the back section. Both the reading lights over the twin beds went out when 3rd fuse pulled so I'm assuming the overhead and bathroom would be on this one. Anyways conclusion is the fuses are ok. Also metered across all three and power good there. Traced the output side wired from fuse box to where they go into the wall pulling, twisting etc. So anyone ever trace down something like this in a Tradewind. Also took cover off the bathroom light and pulled on it's wires, bulbs with no results. any clues?
I've had trouble with this wiring before and eventually it comes back on on its own.
