Old 12-20-2006, 11:50 PM   #1
Creampuff
Creampuff's Avatar
1957 22' Flying Cloud
1971 31' Sovereign
1976 29' Ambassador
Malibu , California
Images: 60
Bargman #6 Tailight- What bulb?
What is the correct lamp number replacement and candlepower for the double filament bulb in a Bargman #6 ? I just discovered #1157's forced into the sockets and they are obviously wrong with offset pins. The correct lamp has pins at the same latitude near the bottom.
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 12-21-2006, 06:55 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If you look in the socket, and see only a single contact in the base, you need a single filament bulb. #1156 or #1141 would be correct bulbs if that is the case.
Old 12-21-2006, 01:19 PM   #3
Creampuff
Creampuff's Avatar
1971 31' Sovereign
1976 29' Ambassador
Malibu , California
Images: 60
There are two sockets and one of them is a single. The other is a double which is the stop/turn i believe. That's the one in question.
Murray
AIR #189
Old 12-21-2006, 01:38 PM   #4
jimmickle's Avatar
2000 31' Land Yacht
Have you tried contacting Bargman? Bargman
jimmickle is offline   Reply With Quote
Old 12-21-2006, 02:05 PM   #5
Images: 59
Murray,
How do you intend to use the double filament? The current standard is turn signal and brake signal using a single filament, and running lights on the other wire.
I like the idea of a separate circuit for the brake lights and turn lights, but I don't know how you get it to work with contemporary tow vehicle wiring circuits and a seven way umbilical.
markdoane is online now   Reply With Quote
Theodore Bargman Box Craig 1978- 1979 Excella 500 26 03-16-2014 04:02 PM
Bargman 99 Question Number99 Lights - Interior & Exterior 18 07-08-2006 10:07 PM
How many Airstreamers does it take to change a light bulb? Foiled Again Off Topic Forum 4 10-05-2005 10:37 PM
Tailight Wiring '62 Overlander Deppdog Electrical - Systems, Generators, Batteries & Solar 2 07-17-2003 08:53 PM
Bargman #99 wedding cake Tail light needed cindy Lights - Interior & Exterior 8 10-16-2002 08:52 AM
