Old 04-09-2014, 07:50 PM   #15
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Should read Norel styrene.
Name:   ImageUploadedByAirstream Forums1397094605.365181.jpg
Old 04-09-2014, 08:10 PM   #16
kmaggard's Avatar
1994 21' Sovereign
Paradise Valley , Arizona
Originally Posted by Flynavy View Post
I just don't know what it is.
When I first started to work on the trailer the backup lights came on as soon as I connected to the truck. Stayed on all the time. Everything else works as it should, although it seems as though the coach batt is not being charged by the truck.
I take apart the truck end connector on the cord and find the center wire ( heavy blue wire) is not connected. I replace the end and hook up the center wire which all info I have says is the backup. Now when I plug into the truck the truck backup lights come on instantly and stay on. The truck isn't even running.
Seems as if the backup wire and charge wire are somehow crossed. How can I track this down
Should the TV charge line have power when the truck is off? If so, wouldn't this allow you to discharge the TV battery when sleeping in a walmart parking lot still hitched up?
I know it is unreasonable to use that much power in one night but I am just using it as an example.
WBCCI# 2520
AIR# 77458
Ken and Ben the Saint
Paradise Valley, Arizona
kmaggard is offline   Reply With Quote
Old 04-09-2014, 09:02 PM   #17
HowieE's Avatar
Princeton , New Jersey
Images: 12
The power from the TV may or may not remain on depending on TV. Newer TV control this by the ignition switch.
2004 Excursion 4x4
Old 04-10-2014, 12:35 PM   #18
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
There is only power to the battery charge wire when the tow vehicle key is turned on.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-10-2014, 02:25 PM   #19
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
OK, I swapped out the blue and black on the cord truck end and the backups now work as they should. It still appears as though the coach batt. is not getting a charge off the running truck. It is getting a charge off shore power. I'll work on that next.
Flynavy is offline   Reply With Quote
Old 04-10-2014, 03:54 PM   #20
Retail6's Avatar
2007 28' Safari SE
Springdale , Arkansas
I just discovered that on my unit as well. I never realized when I bought the TV (2012 Ford F150 Plat) the little package in the glove compartment had an extra fuse and relay in it. This past trip we could not figure out what caused the Batteries to loose power in the AS. So we pulled off I40 in OK at an RV Sales place. Those folks nailed it fast. For the life of me I could not remember where I put that container (Fuse and Relay) . Cost me about $24 total for both - No labor. Really nice folks. Still scratching my head as to why Ford doesn't just install them automatically.
Retail6 is offline   Reply With Quote
Old 04-11-2014, 12:00 PM   #21
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
Yep, that's the problem, nothing comming out of tv. charge line.
Thanks for all the help.
Backup lights? Goin camping Electrical - Systems, Generators, Batteries & Solar 24 01-16-2013 03:26 PM
Tow Vehicle Indicator Light Telling me to Check Trailer Lights, Need Help !%? ericwarren Lights - Interior & Exterior 1 09-07-2009 11:05 AM
Spotted Argosy from road....any way of telling length from # windows??? 75ARGOSY1 All Argosy Trailers 5 12-02-2007 07:07 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
Backup Lights Stay On (Help!) pscottn Lights - Interior & Exterior 4 08-18-2003 11:59 AM
