Old 06-04-2014, 08:53 PM   #1
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Backup lights
I know I saw a thread about this, and now I can't find it. So I apologize for the redundancy.
I recently removed the plastic tail light assembly on my 72 Argosy, which had a 2 bulb set up, one of which was enclosed with a clear reflector type lens. This would lead me to think that it was a backup light. However, the lamp was lit (both sides) when the TV lights were on. Now I'm installing a 3 lamp tail light lens, and when I hook up the TV and put it in R (reverse, not race), I get nada on the lamp with the clear reflector lens. As usual, I thought I had everything documented before removing the old plastic assembly, but now I can't decipher the photos I took during dis-assembly.
I've hooked the TV up to the umbilical cord and put the TV in R - no lights or turn signal - and tested each wire at the rear of the trailer and get no indication of juice.
So two questions: First, when did AS start using backup lights?
Second, if I don't have wiring to accommodate backup lights, should I just "bundle" the hot wires so that when the TV lights are on the lamp in the clear reflector stays on, or should I disconnect it entirely? But then why did the original set up have the clear lens and lamp?
Ok, that's 3 questions.
Name:	Tail light 1.jpg
ID:	213580   Click image for larger version
Name:	Tail light 2.jpg
DryFly is offline   Reply With Quote
Old 06-04-2014, 09:17 PM   #2
1977 Argosy 24
Milltown , Wisconsin
I had a 74 AS that had backup lights, my 78 AS had backup lights, and my 77 Argosy has backup lights. I bet your plug to truck is wired wrong. The center pin on the comon 7 spade plug is used for the reverse lights.
ventport is offline   Reply With Quote
Old 06-04-2014, 10:39 PM   #3
DryFly's Avatar
1972 Argosy 20
I'm suspecting the same thing. I'm hoping somebody comes back and has a '71 with backup lights.
Old 06-05-2014, 07:07 AM   #4
1977 Argosy 24
Check the center pin on your tow vehicle with a test light to see if it lights when the TV is put in reverse. Be careful and don't back over yourself.
Old 06-05-2014, 06:41 PM   #5
DryFly's Avatar
1972 Argosy 20
Well, I tested the center pin on the truck and no voltage from the center pin. Turned on the headlights and got voltage at the appropriate pin on the truck. So I then hooked up a tester to the trailer and confirmed that the wiring does work for back up lights.
I then called the Honda dealer where I purchased the truck and finally got with a tech who spoke electrical. Looks like a bad 7 pin installation on the truck. Fortunately, it's covered under warranty. I'll be taking it in next week for corrective surgery,
Thanks for pointing me in the right direction.
Backup lights? Goin camping Electrical - Systems, Generators, Batteries & Solar 24 01-16-2013 03:26 PM
Backup lights will not go out redhawk Lights - Interior & Exterior 1 10-27-2009 01:27 AM
7 pin plug, no power to backup lights on truck bmklawt Lights - Interior & Exterior 11 03-26-2009 09:27 AM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
Backup Lights Stay On (Help!) pscottn Lights - Interior & Exterior 4 08-18-2003 11:59 AM
