Old 08-28-2015, 08:12 PM   #1
Fullerton , North Dakota
Back up Lights
Has anyone installed back up lights on your airstream travel trailer?
LWinters is offline   Reply With Quote
Old 08-28-2015, 08:30 PM   #2
batman's Avatar
1964 22' Safari
modesto , California
Yes. They work great!
batman is offline   Reply With Quote
Old 08-29-2015, 08:50 PM   #3
Back up lights
we just ordered a 25' international rear bedroom. How did you route the wiring from the front to the back of the trailer?
Old 08-29-2015, 09:39 PM   #4
batman's Avatar
1964 22' Safari
Mine was stripped, I did a ground up on her. So it was easy.
I ran mine from the 7-way plug under the front to a 7-way service box, then routed inside the frame rail (I boxed in my frame rails in for added strength) all the way to the rear. Then up through the floor and C-channel to the back up lights. Same with tail lights, brake lights and running lights.
Sounds like yours will be new. It may be pre-wired, I do not know. Perhaps some one else will chime in here with that. Or, call Airstream or the place you ordered from and ask. Maybe no to late to have them add it to the order? If they do that??
If not and you still want back up lights. You will have to remove the inside skin in the rear to gain access to the back of your lights.
First wire up your 7-way receptacle on the TV, Then see if the pug end has the required unused wire and connect that. Follow that hopefully to a junction/service box. From there you will run a "new" wire and you will just have to follow the existing path of your tail,brake and running light wiring to the rear. Then up through the floor and C-channel to the lights.
-Dennis
Old 08-29-2015, 11:10 PM   #5
1974 Argosy 20
Kooskia , Idaho
Back up lights used to be standard on the late '60s and most of the '70s Airstreams and Argosy's. I don't know when they stopped installing them. I never found them very useful on those trailers I had with them. Yes, they gave a little light back there, but a long ways back and very hard to see anything anyway. I suppose if you have a back up camera on your trailer they would be more useful. I have not missed having them.
And the last thing I want to do is to back up an Airstream at night....kwunch, krinkle.
Back and forth, back and forth.....what 2 do??? WILDRTEXAS Upholstery, Blinds, Walls & Interior Finishes 19 11-30-2009 05:24 PM
Odd back-to-back eBay auctions .... summerkid Trailer Values 5 09-12-2005 12:34 PM
Back-up lights femuse Electrical - Systems, Generators, Batteries & Solar 8 08-19-2004 07:02 AM
back up lights john hd Lights - Interior & Exterior 0 12-27-2002 06:54 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 06:43 PM
