Old 05-27-2015, 03:59 PM   #1
Danny Bell's Avatar
1966 28' Ambassador
Colville , Washington
Back (2) running Lts. work, front (2) don't ?
We purchased a 1966 Ambassador. All exterior lights work including the rear (2) running lights, but not the front (2) R.L.'s. I have no power to the front R.L.'s. I would assume the wire run is to the front first and then spliced to the rear ? I will check the connection panel under the front of the trailer. If it's not there, I'm thinking then it must be in the walls. Is there an easy way to get to the wiring without skin removal ? I'm not going to remove skins for (2) R.L.'s.
Dan
Danny Bell is offline   Reply With Quote
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
Cutter 99 aux hd lts switch landmarc Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 08-03-2010 06:48 PM
Some 12v lights don't work bjstewart1 Electrical - Systems, Generators, Batteries & Solar 6 07-22-2003 05:42 AM
