Old 08-30-2015, 12:54 PM   #1
silvereagle2's Avatar
2014 27' FB International
Cary , North Carolina
Awning LED Light Strip factory install
Once I saw the previews of the 2016 Airstreams on Utube, I wanted it bad: Awning LED light strips standard on many of the 2016 models??? Well, folks since I already had an appointment at Jackson Center to install the awning package (streetside and rear awnings), I called to ask if the factory service guys could retrofit the LED light strip on my existing Zip Dee awning on my 2014 27FB trailer. And about $500 later, they installed it!
They riveted the strip along the aluminum part of the awning closest to where the awning is attached to the trailer side, ran a line into the trailer outside wall directly underneath the left side of the Zip Dee awning arm, and connected it to a new indoor light switch that has a dimmer and built in fuse (just like the switch we already had that controls the indoor cabin LED ceiling lights). It runs off of the 12 volt power, so we can use this anytime - but we have to have the awning out to see the lights. (See pictures attached)
I told the guys at Jackson Center they may be having more people request this once I let the word out.... Enjoy!
silvereagle2 is offline   Reply With Quote
Old 08-30-2015, 01:24 PM   #2
2011 25' FB Flying Cloud
Anywhere & , Everywhere
For 500 bucks I think most will be very happy to do without.
Al - K4GLU is offline   Reply With Quote
Old 08-30-2015, 01:34 PM   #3
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I will keep my $ 500...... And use a flashlight.....
Old 08-30-2015, 02:25 PM   #4
2015 23' International
Charleston , South Carolina
I did this one myself a few months ago. So far so good. See post 40 and 41 on the thread below. About $110 for kit on Amazon but since I have found that you can get materials quite a big cheaper if your willing to look for individual components. No doubt, it is a super nice upgrade.
http://www.airforums.com/forums/f516/awning-lights-for-a-27fb-flying-cloud-123950.html
FollySteve is offline   Reply With Quote
Old 08-30-2015, 02:35 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
$500? I don't think so. $12 from eBay.
MICHAEL
Old 08-30-2015, 04:13 PM   #6
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Silvereagle - any pics?
I too went the $25 route but would imagine their professional installation and wiring looks very good and is worth it!
Mine's a strip of LEDs from Amazon - $25 - peel and stick to the top of the belt line trim. I plug it in to the outside outlet - kludgey, but I'm happy with it too!
Name:	ImageUploadedByAirstream Forums1440972823.182322.jpg
Old 08-30-2015, 04:50 PM   #7
I have tried several times to post my pics, but they always fail to upload. Any suggestions on how to post? Thanks
Old 08-30-2015, 05:00 PM   #8
AWCHIEF's Avatar
Images: 33
Try reducing the size.
MICHAEL
Old 08-30-2015, 07:44 PM   #9
Silver Condo III
kamadeca's Avatar
2015 30' International
Saskatoon , Saskatchewan
Falling Lights
We tried the $25.00 Amazon lights to no avail. Actually did it twice. The first set came unstuck within 24 hours, and the controller stopped working within 12 hours. Returned to Amazon and got another set. This set stayed up for about a week before it slowly started peeling off, and yes, the controller stopped working about the same time!
We followed all the instructions on how to install the lights, including using rubbing alcohol to clean the trailer.
It took us at least 3 hours to remove the glue residue from the side of the trailer.
Never again will I stick anything to the side of the trailer.
Malcolm & Randy
WBCCI # 12523
kamadeca is offline   Reply With Quote
Old 08-30-2015, 07:57 PM   #10
W , New England
I imagine the OP would be happy knowing the relatively large outlay of cash is worth it to avoid issues like this.
On ours, we literally attached it to the top (skyward facing) ledge of the belt - it's not attached to the skin of the trailer at all.
I cleaned it vigorously before affixing it and so far - 6 months later - no problems with the adhesive or the controller (knock wood) but I'll be surprised if they last more than 2 years. We'll see.
Old 08-30-2015, 08:06 PM   #11
AWCHIEF's Avatar
Images: 33
My mounting attachment. Plastic clips and 3M double sided tape. Easily and cleanly removable if necessary.
MICHAEL
Old 08-30-2015, 08:23 PM   #12
2016 30' International
Scottsdale , Arizona
We like the new LED strip; it's pretty cool. Though we probably wouldn't have ordered it at extra cost. Nice to have, though. It was standard equipment from the factory on our 2016 coach.
DHart is offline   Reply With Quote
Old 08-31-2015, 08:05 AM   #13
Mixter's Avatar
1976 27' Overlander
Dont give up- some of us are anxiously awaiting the pics!
Mixter is offline   Reply With Quote
Old 08-31-2015, 03:45 PM   #14
http://www.colonialairstream.com/201.../images/03.jpg
Hope this works.
Old 09-02-2015, 07:07 PM   #15
Link to awning LED picture?
https://flic.kr/p/xctXws
Hope this works - link to Flickr pic
Old 09-30-2015, 02:27 PM   #16
dprvashon's Avatar
2015 25' FB Flying Cloud
Vashon , Washington
Images: 11
2016 Awning Lights - Replacement
I too just got my 2016 25' FC with the awning lights. Haven't tried them yet but during the delivery walkabout, the tech noticed that 2 of the LEDs weren't working so they ordered a replacement strip. Does anyone know how to perform the replacement? I would like to do it myself as it is a pain to take the trailer to the dealer due to ferry fees, time, travel. If it isn't a straight-forward simple process, then off to the dealer I go.
thanks
2016 Flying Cloud 25 FB Twin
2014 Ford F150 3.5L V6 Ecoboost w/ max towing pkg
oh, and Cleo the wonderdog
dprvashon is offline   Reply With Quote
Old 09-30-2015, 03:02 PM   #17
dprvashon's Avatar
Vashon , Washington
Images: 11
2016 Awning LED Fix
I posted the question on how to replace my awning LED strip on our new 2016 25' FC. So here is the answer from the dealer.....
The strip is applied with 3M double backed tape (attached) so you simply peel and stick it to the aluminum base of the awning. The power cable is a simple low voltage power plug like on any electronic device which is then capped. On my trailer, this is up next to the awning above the rear door. The dealer needs the old strip to get reimbursed by Airstream (seems logical) so I simply pulled off the old strip and will reapply the new one from the dealer.
Quite simple really and I don't know why a new/add-on light would cost a lot other than running the 12v wires and installing a dimmer on/off switch. I will check with the dealer on the cost of the strip, not installed.
Oh and another point that was impressed upon me during the delivery.....MAKE SURE YOU TURN OFF THE LIGHT BEFORE RETRACTING THE AWNING OR IT WILL BE ON AND DRAIN THE BATTERY! Another thing for my checklist.
...and there you go
Old 09-30-2015, 03:05 PM   #18
W , New England
Could someone post pics of this? I'm wondering exactly what the LED strip looks like and exactly where it's glued to the awning mechanism. Thanks!!
Old 09-30-2015, 04:26 PM   #19
dprvashon's Avatar
Vashon , Washington
Images: 11
2016 Awning Lights
Okay.... here are a couple of shots of where the lights go and what they look like including the power plug. The LED strip extends the length of the awning minus about 6". It is stuck to a flexible part of the awning base just before the ribbed aluminum. There is a 1" or so strip of flexible material. Again, the power for mine is above the rear door, I assume because it is close to where they put the switch.
Let me know if you have questions.
Old 09-30-2015, 05:48 PM   #20
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
How about a photo of the electrical connection. Thanks
tsunami is offline   Reply With Quote
Over-cabinet LED strip lights...YAY! vinnysca Lights - Interior & Exterior 9 01-26-2012 05:01 PM
LED strip lights / tracks build Darkspeed Lights - Interior & Exterior 0 10-19-2011 10:16 AM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
To strip or not to strip. That is the question. mjmcwhorte Cabinets, Counter Tops & Furnishings 2 01-16-2006 08:10 AM
