Old 10-14-2010, 04:28 PM   #1
nick6930's Avatar
1979 Argosy 27
1969 21' Globetrotter
1953 25' Cruiser
Front Royal , Virginia
Are 1156 lights good for interior lighting?
I am doing some research for my 1953 Cruiser total restore and I am planning on changing all of the 120v light to 12v LED. I plan on keeping the original fixtures but I was thinking of installing 1156 sockets where the edisons are.
QUESTION: What would be the best type of socket to use? My 79 Arogsy has 1156 light sockets but I am not sure if that is the best way to go. A concern of mine is that it may be old style and the prices of bulbs would go up. There are so many kinds I am not sure what would be best or if it would even matter.
Any opinions would be greatly appreciated.
nick6930 is offline   Reply With Quote
Old 10-14-2010, 04:54 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Nick,
There are many alternatives to consider.
First of all you may wish to keep the Edison bases. There are 12 volt LEDs available with a screw base. Here is one example:
DR. LED Bulb-led at West Marine
If you do decide to switch to an 1156 style lamp then there are converters available so you can retain the original socket and mounting hardware
ANCOR MARINE Base at West Marine
But I would not opt for an LED conversion with those fixtures. LEDs do not perform well in fixtures that are not engineered for them, and overall there are still many problems with lamp life, light quality, intensity, and efficiency. Instead, consider fluorescent lamps with a spiral tube, which are available in 12 volt configurations with an Edison base from many sources. Here is one web site, there are many others:
12 volt DC compact fluorescent lights, 3 to 30 watts in spiral, double U tube, or bulbed, soft white and daylight, quantity discounts.
In practice with the kind of fixtures you have you won't get much more useful light per amp from LEDs than with the compact fluorescents.
Finally if you do replace fixtures you might consider the Taylorbrite fluorescent lights that are used in current production Airstreams. I have them and they're great, although I had to replace the tubes with ones with better color. These take up less headroom than the old fixtures - important if you're tall - and produce a lot of light.
Taylorbrite(R)
Old 10-14-2010, 05:32 PM   #3
nick6930's Avatar
1979 Argosy 27
1953 25' Cruiser
Thanks for the info Jammer. We do a lot of boon docking and had just assumed that the LED's that I put in the Argosy was the most efficient. I have a lot more reading to do.
We actually like the amber and red colored LEDs for interior lighting. not for everyone but we like it.
I want to keep the original fixtures and did not realize that I could convert the Edison base to 12v. i hope I did not cut the wiring too short, it may be safer to solder new wire anyway on the 57 year old base.
Thanks again.
Old 10-14-2010, 05:54 PM   #4
x
XXXX , XXXX
Nick the sockets may be the same as 1156 but you should be using 1141 bulbs. The 1141's don't burn as hot and won't melt your lenses. 1156 are for cars and burn a lot higher and brighter. I can't tell you how many trailers I have seen with holes melted into the lenses from people using the 1156 bulbs.
wasagachris is offline   Reply With Quote
Old 10-14-2010, 07:54 PM   #5
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Here's this from Sean in the Long Long Honeymoon
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
led, 1156 bulb
LED lighting retrofit for interior lights Westfalia Lights - Interior & Exterior 372 12-17-2016 11:43 AM
