Old 08-16-2009, 10:52 AM   #1
1995 21' Sovereign
Tracy , California
Anyone out there with ammeter/shunt experience?
I bought a nice ammeter/voltmeter/watt meter for my 1995 Sovereign.
It has a shunt which is meant to be installed in negative (ground) lead
between batteries and the rest of the electrical system. The shunt is used to generate a signal for the ammeter/watt meter.
Problem is the manual has lots of information regard hot side of circuit.
Very little information regarding ground side. Wiring diagrams all show connections to ground, but very little information regarding physical arrangement of ground wires.
The trailer is a 21 foot with two battery cases up front. The black cables come out of the battery cases then disappear behind aluminum.
Does anyone have experience hooking up a shunt in an Airstream?
johnobuttons is offline   Reply With Quote
Old 08-16-2009, 11:41 AM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
This is how I did it on the '78 Sovereign
Don't know about the '95, but on the '78 the ground (negative) battery leads are also fused, if this is the case (they are individually fused), the wiring will have to be modified to combine the leads to only one line to go through the shunt.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 08-16-2009, 11:40 PM   #3
1995 21' Sovereign
Tracy , California
Smile Progress on installing shunt for ammeter
Thanks Dennis,
It's nice to see a picture of the shunt/battery in a vintage trailer.
I finally got the ground wiring for the 95 Sovereign figured out today. The Sovereign has two batteries, but no fuses or shunts in the negative leads.
The negative leads from the two batteries apparently join in the 12V distribution box under the front window. (see pictures)
The grounds are all at the lower left. In order to insert the shunt, I removed
the two black wires going left and right at the top of the ground block.
I removed these two black wires from the ground block and attached them to one side of the shunt. Next I ran a black wire from the other side of the shunt to the ground block.
The ammeter/wattmeter works fine. I'll figure out how to route wires and make things pretty next weekend and then post some pictures.
If anyone wants to put in an ammeter/watt meter/voltmeter, I got mine on ebay.
Digital DC Boat Golf Solar Power Watt Volt Amp Meter - eBay (item 350239500736 end time Aug-19-09 19:58:57 PDT)
John
Name:	Circuit Box.1.jpg
ID:	85507   Click image for larger version
Ammeter Vs Ampmeter kennytheecat Electrical - Systems, Generators, Batteries & Solar 16 04-16-2009 12:56 PM
TriMetric 2020/2021 shunt - 100 or 500 amp? ostream Electrical - Systems, Generators, Batteries & Solar 3 11-06-2008 02:37 PM
Ammeter need William8979 Electrical - Systems, Generators, Batteries & Solar 1 01-28-2007 07:32 PM
Can-Am RV Experience?? Craig Commercial Listings 20 10-05-2004 07:30 PM
Ammeter smily Electrical - Systems, Generators, Batteries & Solar 14 08-12-2002 09:09 PM
