Old 11-08-2014, 12:35 PM   #1
Mixter's Avatar
1976 27' Overlander
Anyone know of LEDs for the rear marker lights on mid '70s on the tail lights?
Trying to figure out what to do for these lights:
Red Marker Light 510984-01 [510984-01] - $12.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
I want to do LED's, but I cannot find a direct replacement. Trying to avoid using my old lens and case to retrofit LED's into it because its old, not replaceable and I fear the lens could fall out.
Any ideas are welcomed.
Thanks!
Micky
Mixter is offline   Reply With Quote
Old 11-08-2014, 01:02 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Check out led4rv.com. They will have what you need.
MICHAEL
Old 11-08-2014, 02:29 PM   #3
Zil
egg harbor city , South Jersey
You should be able to replace the bulb. here are many replacement bulbs,
https://www.superbrightleds.com/cat/...acement-bulbs/
Zil is offline   Reply With Quote
Old 11-08-2014, 03:31 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
You may want to consider what I did. Look at post 45, 49, and 51 on
http://www.airforums.com/forums/f311...s-23544-4.html
These are so bright and I added a sequencer to turn them on 1, 2, 3 as brakes and directionals. There is no guess work as to what I am goig to do when they are on.
2004 Excursion 4x4
Old 11-08-2014, 04:26 PM   #5
Mixter's Avatar
1976 27' Overlander
Yeah, I've tried led4rv, superbrightleds, and even the grote.com website. I'm coming up short so far.
These marker lights I'm looking for fit into a recess in the tail light housing that measures 3 5/8" tall by 2" wide. Odd size, since most markers are like the double bulls eye which measure 4" x 2".
I sure would like to find a housing that would work. I found a 2 7/8" x 2 marker light. not too far off, but I'd have to fill my holes and mount differently because the originals are standard 3" on center mounting.
I'm surprised there is not a solution for this. All the other lights have a replacement.
Old 11-09-2014, 10:38 AM   #6
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
A Mustang Airstream!!!
SuzyHomemakr is offline   Reply With Quote
Old 11-10-2014, 06:31 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
That actually started with the 1967 Mercury Cougar. Ford carried it over to other models because it is retro cool.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-11-2014, 04:39 PM   #8
1972 23' Safari
Burlington , Kentucky
Mixter....are you wanting to replace the taillight canisters as well aas the bulbs abd lenses? Last year when redoing our 72 Safari I replaced the canisters (got from Vintage Trailer supply VTS610.) also got the lenses Clear and Red (they dont come with the cans). It used the STANDARD bulbs. I was looking into the LEDs and Inland RV does list some for a 69 to 74. Id give Andy at Inland RV a shout. warning....the items arnt cheap.
Debnw is offline   Reply With Quote
Old 11-11-2014, 08:27 PM   #9
Mixter's Avatar
1976 27' Overlander
No- not replacing the whole assembly, but mine are different than yours. I think they changed design from 1974 to 1975. Mine is a '76.
I actually refurbished mine and pretty pleased the way they came out. I copied Aerowood and installed helicoils so I could fasten them back on better than the original pop rivet. Now that they are all shined up, painted and sealed (man I can't believe there was ZERO sealant on these lenses??? What was Airstream thinking???)
So now that they look good, I've decided to go LED. I bought these for the marker lights because I like the black bases. My renovation theme is black and silver: https://www.superbrightleds.com/more.../Photos&Videos
I'm buying these for tail lights: Sealed LED light kit for old 4.25 Monarch LED-kit2 [LED-kit2] - $179.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Sooo.... if I'm doing some, I'm doing all. Still looking for the Scare light in LED, and the license....
Its that one single little light on my tail light has no direct replacement that I can find.... my options are to use the old plastic, and put in new LED's, OR I've found some motorcycle LED's that are slightly too small, but I can get them to work.
Still hoping someone found a perfect fit
ID:	226303   Click image for larger version
Marker Light LEDs for Teardrop robwok Lights - Interior & Exterior 0 09-12-2014 08:09 AM
Rear Marker Lights and rear window awning Lumatic Lights - Interior & Exterior 1 12-26-2012 12:07 PM
Help with Tail light and marker lights 60's Iron Electrical - Systems, Generators, Batteries & Solar 8 08-19-2006 01:37 PM
Lighting up the Marker and tail lights for show startrekker2001 Electrical - Systems, Generators, Batteries & Solar 9 06-01-2006 06:36 AM
